Convention in rating speaker impedance
Serendipity
Serendipity Posts: 6,975
edited December 2011 in 2 Channel Audio
Never mind, figured it out...
polkaudio RT35 Bookshelves
polkaudio 255c-RT Inwalls
polkaudio DSWPro550WI
polkaudio XRT12 XM Tuner
polkaudio RM6750 5.1
Front projection, 2 channel, car audio... life is good!
  • Serendipity
    Never mind, I think the issue is with the receiver.
    http://www.polkaudio.com/forums/showthread.php?126965-Why-do-the-new-Onkyo-TX-NRx09-receivers-sound-so-bad-for-music
    Newer Onkyos = less current.
  • Drenis
    Drenis Posts: 2,871
    Not that it helps... but the RTi A9's are a 8-ohm speaker that dip down to 4.5 ohms. I think this is standard with many speakers where the impedance will dip depending on frequencies?
  • quadzilla
    quadzilla Posts: 1,543
    Yes, it's normal. But if the speaker is rated at 8 Ohm nominal, then it's fine if the AVR/amp is also rated for 8 Ohm speakers.
    Turntable: Empire 208
    Arm: Rega 300
    Cart: Shelter 501 III
    Phono Pre: dsachs consulting
    Digital: Marantz SACD 30n
    Pre: Conrad Johnson ET3 SE
