2 Channel System
mara5
mara5 Posts: 54
edited December 2011 in Electronics
In a dedicated 2 ch. which would be better, a 2 ch. amp. or an integrated amp? Source is a Yamaha RX-v870.
Post edited by mara5 on
  • Erik Tracy
    Erik Tracy Posts: 4,673
    Your source is an avr - is your question on how to combine an HT system using your Yamaha and add 2-channel?
    If you are strictly building a 2-channel system, I'd start from scratch with 'true' 2-channel components and ditch the AVR as a pre.
  • mara5
    mara5 Posts: 54
    Well good question Erik! My music mostly comes from Sat. thru the Yammy. I thought that I could purchase either a strict 2 ch. amp or an integrated amp, and run it off the Yammy?
  • Erik Tracy
    You can keep your AVR and build a hybrid HT/2-channel system - guess it depends on how strongly you feel about going pure old school for 2-channel.
    I built a hybrid system by getting an integrated amp that has a feature called "HT Direct" (or HT "Bypass"). This allows you to keep the AVR for multi-channel setups and speakers by feeding the Front L/R preout signals to the integrated amp so that when watching movies the integrated amp is nothing more than an amp (volume is controlled by the AVR).
    But for 'serious' 2-channel listening - all of the source components for turntable, CD, SACD, etc are directly connected to the integrated amp and the AVR is turned off.
    You can certainly add an external amp to your Yamaha and realize some sonic gains w/ good amplification, but - imo - the AVR will be the weak link as the pre-amp if you really want to step up your 2-channel system.
    I did this with my Yamaha RX-V1800 - added an amp first, but went with the integrated amp with HT Bypass. To me, waaay better sounding.
  • falconcry72
    falconcry72 Posts: 3,580
    Erik, I think this is for a strictly 2-channel system, no ht bypass needed. Correct, mara?
    If this is the case, you'd use your yammy as a preamp, and connect it to a poweramp via its preouts; however, I'm not sure that your yammy has preouts... I looked at the manual and couldn't tell what the "coupler" section was.
    http://www2.yamaha.co.jp/manual/pdf/av/english/re/RX-V870.pdf
    If your yammy does have preouts, then you would connect it to a 2-channel power amp via RCA cables. You would not connect it to an integrated amp, because an integrated amp is basically a preamp and power amp in one, which you wouldn't want because your yammy is already preforming preamp duties.
    If your yammy does not have preouts, then you would have to start over. In this case, you could go with an integrated amp as a generally less expensive option, or separate pre and power amps as a generally better sounding option. Take note of the *generallys* in that last sentence.
    It seems like you want to keep the yammy because it's providing a signal from a Satellite? How is it connected? You may be able to use something else.
  • mara5
    mara5 Posts: 54
    Falconcry 72, you hit it right on the head. The Yammy has preouts. Would use the Yam. for a pre,and then an amp, to speakers. I like the sound of the Yam. and saving 1k-ish on some type of tuner ,whatever. I'm not looking for audiophile quality, just very good sound. My speakers were delivered today (Kef XQ40's). What amp would compliment the speakers and Yam? The 40's run just a little bright, so looking for a warmish type amp,$1500 ish. Thx Joe
  • falconcry72
    mara5 wrote: »
    ...so looking for a warmish type amp,$1500 ish. Thx Joe
    hmm. Keep in mind I've never heard that Yamaha, but...
    I think that given your speakers, and if you spent 1500 on a poweramp, that Yamaha would be an obvious weak link, not allowing you to get the best out of the other pieces. I think you'd be better off splitting that 1500 50/50 on a 2-channel pre and 2-channel poweramp. Just off the top of my head, the classic Adcom GFP-750 and GFA-5802 combo can be had for 1500, but there are many many other choices out there. Interested in tubes?
    For 1500 bucks, you can find it, if you want it.
  • mara5
    mara5 Posts: 54
    THX Falcon, gives me some food for thought.
  • pearsall001
    pearsall001 Posts: 5,328
    I see you're still driving yourself nuts!!! You haven't had the XQ 40's long enough to form an opinion yet. You think they sound bright????? WOW!!!! That Yammie has plenty of juice to drive them. Why not hold pat till you log some miles before jumping all over the place. Enjoy them with what you have & then start looking ahead...maybe you won't even have to. Just a thought, good luck!
    Yamahas can be a little bright, and it seems like you're stuck with the Yamaha if you're main source is SAT/dish tunes. But the 1800 is not the "worst" offender there. Lower level Yammies are much brighter.
    You need some warmer sounding amps: Carver, Parasound, NAD, B&K maybe? Listen to some and see what sounds best to you.
    cnh
  • Erik Tracy
    For $1500 - buy this and call it a day - would be way better that any avr/amp combo.
    http://www.audiogon.com/cgi-bin/cls.pl?intatran&1327104840&/Musical-Fidelity-A5-Very-Clean
  • mara5
    mara5 Posts: 54
    Hi Phil, as usual sound advice, but everything I've read about the 40's indicates they need an amp to reach their potential. I'm not rushing into it. Just want the right info for when the time comes. Joe.
  • mara5
    mara5 Posts: 54
    Erik, it's gone already.
  • mara5
    mara5 Posts: 54
    Phil, No I don't consider them bright. Have not hooked them up yet. A couple of the reviews I read said that they were slightly bright, or leaning that way,etc. I haven't bought any speaker cables yet, so debating hooking up now with bargin basement wire, or waiting till next week, when I head to Omaha. Joe.
  • Erik Tracy
    The Musical Fidelity products usually do go fast.
    If you don't mind buying used - audiogon.com can be a good source of really good values that will definitely step up your 2-channel system.
    I'm a fan of MF - I got my A5 int amp from audiogon, but there are some other really nice values too to watch for - Rega Brio integrated amps pop up for very fair prices and are highly regarded. Or maybe a Cambridge Audio integrated, Music Hall, Creek, and more.
    This MF is still available at a nice price:
    http://www.audiogon.com/cgi-bin/cls.pl?intatran&1328146825&/Musical-Fidelity-A3.2
    It doesn't have HT Bypass, but since that is not a feature you need - could be worth considering.
