Do laptop die? Not a battey.
disneyjoe7
disneyjoe7 Posts: 11,435
edited December 2011 in The Clubhouse
Dell XPS M140 laptop, having some problems. Screen goes lines, laptop locks up.... I took it apart and rebuilted / cleaned it out. Reinstalled Ubuntu 11.0.4 still have issues, so downloading 11.0.10 (I think on another computer, since this one locked up before it got it.)
Can motherboard die? It's 6 year old. Yes I'm cheap.
Speakers
Carver Amazing Fronts
CS400i Center
RT800i's Rears
Sub Paradigm Servo 15
Electronics
Conrad Johnson PV-5 pre-amp
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
Sony CX400 CD changer
Panasonic 42-PX60U Plasma
WMC Win7 32bit HD DVR
Post edited by disneyjoe7 on
  • ryanjoachim
    ryanjoachim Posts: 2,046
    Yeah, it can die...but the lines on your screen makes me lean towards a GPU issue firstly. Possibly a heat issue?
    MrNightly wrote: »
    "Dr Dunn admitted that his research could also be interpreted as evidence that women are shallower than men. He said: "Let's face it - there's evidence to support it."
    mystik610 wrote: »
    Best Buy is for people who don't know any better. Magnolia is for people who don't know any better and have more money to spend.
    My System:
    TV: SAMSUNG UN55B7000 55" 1080p LED HDTV
    HTPC: Chromecast w/ Plex Media Server. Media streamed from Media Server.
  • disneyjoe7
    Not a heat issue, I rebuilt it and put some grease to between heat pipe and cpu. And computer is only one for 3 mins or so.
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
  • quadzilla
    quadzilla Posts: 1,543
    It's a 6 year old computer. I'd say you're lucky it lasted this long.
    Turntable: Empire 208
    Arm: Rega 300
    Cart: Shelter 501 III
    Phono Pre: dsachs consulting
    Digital: Marantz SACD 30n
    Pre: Conrad Johnson ET3 SE
    Usually when a Dell does that something is wrong with the video board or more! I have a 6 year old (institutional Dell) that started to do that two years ago. ITS took out my hard drive and put it in another used unit--have been running ever since.
    Yes! Laptops do "die". I'm due for a new one and this one could probably "go" at any moment. lol 6-7 years is a pretty good run these days!
    cnh
  • disneyjoe7
    Not even sure its the video card issue, this laptop only has a video circuit on the motherboard. The mouse locks up, I can't click anything at times. It seems do this on either Wins xp Pro or with Ubuntu. HD been replaced, and memory has been upgraded, years ago.
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
    Hmmm...something like that happened to my wife's fairly new Dell recently. Does an external mouse not work or is it the track pad, or both?
    What I did as a temporary solution for her till we could get it to our Tech Dept., was disable the Track pad and make it external mouse only--this seemed to work in the SAFE mode. ITS solved the problem, not sure what they did, but I suspect they did a wipe and re-install of Windows 7. I'll ask her if she knows anything more about this...but I doubt it.
    cnh
  • Glowrdr
    Glowrdr Posts: 1,103
    I think the GPU idea is right. I repair and see laptops (mostly Nvidia chipsets) that need to be reflowed. The heat releases the chips from the motherboard. Regreasing wouldn't resolve this issue.
    Check your local craigslist - should be something that can be fixed for about $50 locally.
    65" Sony X900 (XBR-65X900E)
    Pioneer Elite SC-37
    Polk Monitor 70's (2)
    Polk Monitor 40's (4)
    Polk Monitor CS2
    Polk DSW Pro 660wi
    Oppo BDP-93
    Squeezebox Duet
    Belkin PureAV PF60
    Dish Network "The Hoppa"
    VR3 Posts: 29,429
    Did your name use to be GoingGanzo?
  • inspiredsports
    inspiredsports Posts: 5,502
    That's my take on it too. Graphics card.
    Conrad Johnson PV-5 w/mods
    MF x-DAC V8, HAInfo NG27
    NAD SS rigs w/mods
    GIK panels
  • disneyjoe7
    Ubuntu 11.10 is installed and seems to work ok. Can't install Google Chrome, its states an internal problem. I'm working on it now with Firefox, and I found out my wireless mouse chick switch was dirty so it wasn't working. I cleaned it with some electronic cleaner, and now place it in a plastic bag to keep it clean.
    Knock on wood I see if it still works later.
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
  • Glowrdr
    Assuming this is meant for me? lol - nope. I'm guessing that's a good thing for me? Those questions usually don't start out as "Hey - aren't you the really cool guy that got banned and had to change his name"
    I used to have an '83 Cutlass w/ t-tops. Lowered, Craiger S/S rims, and chrome duals all the way to the tires. Also happened to have purple neon lights under it (brand: Low Glow). So I was the Glow Rider. Just one of those names that hasn't been appropriate for over 15 years now, but never got changed once I started using it :redface:
    Pioneer Elite SC-37
    Polk Monitor CS2
    Polk DSW Pro 660wi
    Oppo BDP-93
    Squeezebox Duet
    Belkin PureAV PF60
    VR3 Posts: 29,429
    Actually I was asking Steve (Disneyjoe) that - Goingganzo is a member here that could not spell to save his life - we use to joke about a decoder ring
  • disneyjoe7
    Goingganzo is a member here.
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
  • Sherardp
    Sherardp Posts: 8,038
    6 yrs is a really good run on a laptop. Do you have everything working on it now? Not sure what you can do about grahics card but if it is built into the mobo which most are, you will have to replace the board. Most times it's cheaper to buy new laptop at that point. GL bro.
  • disneyjoe7
    Well the laptop is working for the last 2hrs ok. My issue was that Ubuntu Google Chrome when I opened it with many screens at work and only at work it would only open the first screen. When I would click another screen it clicked, clicked, clicked to the first screen. So after several months of that crap, I pulled the laptop apart to clean it (never did that before) it still gave me problems. So thinking the Laptop was dieing, I installed the OS again, then it started with the graphics screen problem. Since I never seen that before started thinking the motherboard was dieing for sure. Now all is good, running Ubuntu 11.10 OS.
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
  • Sherardp
    When in doubt add more RAM, which could be problem to things being a tad slow. 2gb of RAM is not much by today's standard, so it seems.
  • disneyjoe7
    2gig is max this laptop can do, 1gig per slot.
    BTW Ubuntu 11.10 runs really nice, fast and looks great. Love it my 6yr old laptop lives on. :cheesygrin:
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
  • exalted512
    exalted512 Posts: 10,735
    i have the exact same laptop. It started having issues so i reinstalled windows. worked great for a while. started having issues again about a year ago. Reinstalled windows. Still doesnt work right. It had a good run. :(
    -Cody
    2 gigs? I've been running XP with 1 gig for the last six years on a 1.6 Ghz processor. I don't do much high end processing so this is plenty fast. For basic functions, you don't really need much (Word, PPT, Chrome, Media Player, etc.).
    I've been wanting to upgrade my netbook, though, to 2 gigs because the 1 gig on my Dell is about twice as fast (or more) as 1 gig on a netbook.
    Glad to hear things resolved themselves Steve!
    cnh
  • Sherardp
    Lasareath wrote: »
    laptop made by man. all thing man make die. if made by god last for at least 2000 years.
    Buy yourself a new laptop!
    and please stop speaking like caveman
    LMAO!!! I was wondering why you were typing like that.
  • dorokusai
    dorokusai Posts: 25,576
    I'm betting the operator caused more problems than were thought to be fixed. It's junk, get rid of it and upgrade.
  • disneyjoe7
    dorokusai wrote: »
    HeHe... Maybe my 40 screens open at times, I needed to have 2 Google Chrome webs open. But it does what I what so it works.
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
