Speaker Placement
Danny_69
I was just wondering if my speaker placements are okay?
Ignore the 5.1 speaker on the couch, sorry.
And the other surround speaker is at the same height on the corner
Any suggestions for better placements?
Any advice would be helpful
Thank you all
I hope I place in the correct section
Thank you all
Post edited by Danny_69 on
Carefull opening the door!Main Rig:
Nakamichi EC100 Active xover
MIT exp 1 ic's
Perreaux SA33 class A preamp
AQ kingcobra ic's
OPPO 83 CDP
ADS L1590/2 Biamped
MIT exps2 speaker cable -
soundfreak1 wrote: »Carefull opening the door!
Haha its all good. My nephew usually comes storming in, pushing the door. Nothing serious. The door just hits the bottom plate and bounces back
