Best way to break in a new woofer?
Serendipity
Serendipity Posts: 6,975
edited December 2011 in The Clubhouse
My new woofer arrived today - what's the best way to break it in for sound quality, not output?
I want fast, clear, and accurate bass.
polkaudio RT35 Bookshelves
polkaudio 255c-RT Inwalls
polkaudio DSWPro550WI
polkaudio XRT12 XM Tuner
polkaudio RM6750 5.1
Front projection, 2 channel, car audio... life is good!
Post edited by Serendipity on
  • cristo
    cristo Posts: 231
    Well, if you plugged it into the wall you'd get (let's see ... 8 ohms 120 volts 15 amps - that makes 1800 watts)
    a nice 60 hz break in signal at 1800 watts - oops, a little to robust, it'll make the woofer bust.
    How about through a 120 to 24 volt transformer - that's 72 watts - that might work.
    Seriously though, if you have 2 woofers you can put them close to each other, reverse the phase on one of the speakers,
    and drive both with the bass up and the treble down at a robust level of music signal well below the clipping/distortion
    limit of the amp and it will do a good job without driving everyone crazy or hurting anything.
    cristo
    NAD C 545BEE cd player, Philips AF877 turntable / Shure V15V-MR with JICO SAS stylus,
    Tascam 122 mkIII cassette deck, Harman Kardon 3480 receiver, Terk FM-50 antenna in the attic,
    Soundcraftsmen SE550 stereo equalizer, Polk Monitor 10a speakers
    (with Sonicraft/Solen/Mills crossover rebuild)
  • decal
    decal Posts: 3,205
    Just put it in your system and use it.
    pitdogg2 Posts: 25,738
  • WilliamM2
    WilliamM2 Posts: 4,782
    I'd find a better enclosure.
  • rebuy
    rebuy Posts: 695
    If you use that box, be sure and put an air hole in it. That will keep it running cooler.
  • dorokusai
    dorokusai Posts: 25,577
    Polk cooks subwoofers for testing in the dozens at a time using pro-amps at HQ. It's weird to see 25 subwoofers running low end test tones and jumping in unison. There's a pic from the Polkfest in 2005 showing about 30 drivers being tested in the back...not sue if it was ever posted.
    They don't reverse phase or anything like that.
  • Serendipity
    I ran it at low levels before putting it into an enclosure...
    Everything seems to be fine.
    VR3 Posts: 28,804
    Wall Socket, 60 cycles baby!
  • codyc1ark
    codyc1ark Posts: 2,532
    Not trying to be a huge dick, but you have almost 6200 posts and your seriously asking this question? I know thats semi dickish, but come on man...
    VR3 Posts: 28,804
    Now now!
    My "break in" is usually pop it in and crank it loud!
  • Serendipity
    Cody,
    I was told that breaking in a subwoofer with loud explosions or hip-hop music will make the surround weaken, not sure if that was true or not. Cristo's "put them out of phase and run at low levels" made the most sense to me.
    VR3 Posts: 28,804
    Booo - just crank it man!
    New woofers are next to indestructible...
  • SDA1C
    SDA1C Posts: 2,072
    Drive it like you stole it man! They made lots of 'em!
    Too much **** to list....
  • cristo
    cristo Posts: 231
    I actually said "reverse the phase on one of the speakers, and drive both with the bass up
    limit of the amp" - not low levels, but not higher than the amp was meant to go either.
    cristo
  • chadam44
    chadam44 Posts: 68
    Drop it in the box and turn on something bass heavy, or maybe go find some THX test tones and runs those for a while. Or you could just use it as you plan on using it and eventually it gets broken in, sounds better, and it requires no out of the way work for you to arrange for break in.
