Something's amiss with my turntable.
DaveHo
DaveHo Posts: 3,585
edited February 2012 in 2 Channel Audio
The setup:
ProJect Debut III
Ortofon OM 5e cart with OM 10 stylus
Cambrdge Audio 640P prono-pre
Onkyo PR-SC885 pre/pro
I'm the second owner of the table, but have been using it for a few months. I changed out the original OM 5e stylus for the OM 10 because the original got damaged when the previous owner installed the guard before shipping it to me. Supposedly, the table had less than 50 hrs on it when I bought it.
The problem:
Everything was fine until the other day. Then I noticed starting about 1/2 to 2/3 or the way through an LP side, the vocals started to sound very grainy, the sound stage was collasping, & the bass was sounding weak. First track or two sounded fine then the sound would go to crap. The closer it got to the end, the worse the sound was getting. Now last night while trying to trouble shoot, the sound started randomly cutting in & out.
I pulled the 640P out of the equation & connected the TT straight to the phono input on the processor. No change so it's nothing to do with that. Table is level. Tracking force is OK(assuming the built in scale is accurate). Antiskate weight is set right. I have not checked the alignment since I got the table, but nothing looks like it moved.
I use a Last brush for cleaning the stylus. I drag it back to front a couple times after each side & use the fluid with the brush after each listening session. I don't think I tweeked the stylus. Looks OK to me.
So what's the problem? Cart going south? Bad tonearm wiring? Something else?
Help! I need my vinyl fix!
-Dave
  • quadzilla
    quadzilla Posts: 1,543
    edited December 2011
    The position of the arm shouldn't affect the cart like that unless it's moving towards a large magnetic field. Sounds morel like alignment or wiring.
    Turntable: Empire 208
    Arm: Rega 300
    Cart: Shelter 501 III
    Phono Pre: dsachs consulting
    Digital: Marantz SACD 30n
    Pre: Conrad Johnson ET3 SE
  • thsmith
    thsmith Posts: 6,082
    Sounds like cart alignment to me.
  • rebuy
    rebuy Posts: 694
    I think it's broken.
  • george daniel
    george daniel Posts: 12,096
    Get that stylus under a good magnifier and take a peek,,then report back.
  • DaveHo
    DaveHo Posts: 3,585
    Just had a revelation. The night before I noticed the issue, I dozed off & woke with the needle in the runout groove. I didn't think much of it, but could that have f'd something up? Why do the first couple tracks sound OK? Why did it just start cutting in & out last night? Ugh, I hope I haven't trashed any of my vinyl.
    -Dave
  • rebuy
    rebuy Posts: 694
    Here's a link to good stylus info with drawings and photos to help you with the needle if that is the problem.
    http://www.vinylengine.com/turntable_forum/viewtopic.php?t=22894
  • DaveHo
    DaveHo Posts: 3,585
    Back from the dead with an update. This whole situation kind of discouraged me & I quit listening to vinyl for a couple of months. I finally got my act together a few weeks ago & checked everything out.
    Everything with the table setup is fine. Alignment is dead on according to the gauge which came with the table, VTF is correct, etc. Once I verified all that & convinced myself I wasn't destroying my vinyl with each play, I pulled out one of the better recordings I have & gave it a spin. It sounded excellent all the way through.
    It would appear what I was previously hearing is inner groove distortion. The cutting in & out was due to something completely unrelated. Now that I've been spinning again for a couple of weeks, I'm experiencing varying degrees of this on many recordings. Most of which are recent purchases of used recordings from a few different sources. There are a few that sound excellent, but they are few & far between.
    I've read up about IGD & think I gave a grasp on what causes it. Since the current alignment is fine & I can't do anything about the quality of the recordings, I'm leaning toward ditching the Ortofon in favor of something that will track better. The Audio Technica 440Mla seems to get high praise for fighting IGD. I know there are a few others here with Pro-ject Debut III's. What are you using?
    -Dave
  • Joe08867
    Joe08867 Posts: 3,919
    Did you notice the problem before you left the needle in the runout? If not my guess is the needle is worn. You can replace just the needle and not the whole cart.
    If you prefer to replace all that is up to you.
  • skipf
    skipf Posts: 694
    If you used the alignment tool that came with the turntable that may be causing your problem. Not all turntable protractors are equal, and the distortion on inner grooves sounds to me like an alignment problem that will show up more on some recordings.
  • Gavin.Wright
    Gavin.Wright Posts: 125
    I've had good luck with the Shure M97xe - although it's probably not considered an audiophile cartridge i've been happy with the results. I used to use an older ortofon cartridge - TM14? which I replaced the stylus on but was never happy with the IGD or how it handled sibilance.
  • Gavin.Wright
    Oh - I also spent a lot of time with a protractor and a couple of test records to get things setup just right. Well worth the effort.
  • scottyboy76
    scottyboy76 Posts: 2,905
    12 years ago, after the better part of a fifth of wild turkey 101, and a couple of big fat dark madura wrapper Punch cigars, i woke up, or more like regained conciousness, with a copy of Don Rickles classic, "Hello Dummy" on the tt, power off, with the neede in the runoff groove.
    Did no damage or anything, but i know i will never again have a chance to share that story.
    humpty dumpty was pushed
    Sorry to hear about the problem. I use an Ortofon Cartridge on an old Technics SL. Never had a problem with it.
    On that note. Do any of you remember when you were a kid and used to play records on your parents' modest record player and how they always just played and played and played and all you did was replace a stylus once in a blue moon. Sure the player didn't cost a fortune and it was probably wearing your LP away but it sure seemed "indestructible", didn't it?
    cnh
  • hochpt21
    hochpt21 Posts: 5,423
    I am really glad you had the chance to tell it. Thouroughly enjoyed it.
  • scottyboy76
    hochpt21 wrote: »
    I do what i can
  • newbie308
    newbie308 Posts: 847
    Is this a P-mount cartridge or a standard 1/2" mount? I had a similar experience with my dad's old Garrard TT. The problem was dammaged insulation on the tone arm wires shorting to the chassis when the arm was in certain positions, and intermitently at that. I replaced the wires, and the problem never returned. I'd disconnect the TT from the system and the cartridge and ohm out all of the wires to the chassis and to each other.
  • doctor r
    doctor r Posts: 837
    Newbie308 has a good idea. In addition really cleaning your stylus may improve the situation. I have had a stylus run over night with no true ill effects. They can, though, actually pick up and have a coating of crud (dirt, plastic /vinyl polymer, ect) that is difficult to see with the naked eye, but effects the stylus - grove interaction. Look for write ups on the web for using the magic erasure for cleaning your stylus. I have resurrected a couple of cartridges thought to be destroyed using it.
    The set up guide/protractor that comes with your table might get you in the alignment ballpark, but there are better protractors and they can really improve the issue you are experiencing. When I do my alignment and think it is correct I listen for a few days and then recheck, usually redo a small amount, and repeat. I have taken over a month or more to get the setup as good as I can. (one cartridge I worked for more than 6 months and found improvements each time I revisited the setup.) You can download some printable arc protractors to check your set up against from the vinyl engine website. Patience is your friend with TT setup. Work diligently with this cartridge and the experience will pay off in how well you set up your next upgrade cartridge and the one after and the one .........
    Rick
    integrated w/DAC module Gryphon Diablo 300
    server Wolf Alpha 3SX
    phono pre Dynamic Sounds Associates Phono II
    turntable/tonearms Origin Live Sovereign Mk3 dual arm, Origin Live Enterprise Mk4, Origin Live Illustrious Mk3c
    cartridges Miyajima Madake, Ortofon Windfeld Ti, Ortofon
    speakers Rockport Mira II
    cables Synergistic Research Cables, Gryphon VPI XLR, Sablon 2020 USB
    rack Adona Eris 6dw
    ultrasonic cleaner Degritter
