M60's for rears with m70's front?
SolidSnake1988
Hello. I have pair m70 front. Cs2 cente and a psw505 sub. Can the m60 work for rears since its in special at newegg. Or you recommend m40. I was also thinking another pair of m70 for rears. Any opinions or ideas will help. Thank you.
Speakers Polk Monitor 70's (Cherry) Cs2 (Black)
Subwoofer Polk Psw 505
Receiver/Amp Yamaha RX-V671
TV Samsung 46" LED
Entertainment/Blu-Ray Sony Playstation 3 1TB
Interconnects MIT Terminator 4-Emotiva Speaker Cables, Audioquest HDMI
TV Samsung 46" LED
Post edited by SolidSnake1988 on
I have the same front stage as you. My 40's are surrounds and I have 30's as wides but soon to move to rears. The 40's work great as surrounds.
My next upgrade in the not so distant future is either the RTi A9's or the RTi12s. I'll upgrade my center as well, but the 70's will move to surround and the 40's will pull rear duty.
Does that help at all?
What are you driving them with?Source: BRP Panasonic UB9000, CDP Emotiva ERC3 - Display: LG OLED EVO 83 C3 - Pre/Pro: Marantz 8802A - Amplification: Emotiva XPA-DR3, XPA-2 x 2, XPA-6, Speakers, Mains/2ch-Focal Kanta No2's, C-LSiM706, S-702F/X, RS-RTiA9's, WS-RTiA9's, FH-RTiA3's, Subs - Epik Empire x 2
Cables: AudioQuest McKenzie XLR's/CDP/Amp, Carbon 48/BRP, Forest 48/Display, 2 channel speaker cable: Furutech FS Alpha 36 12AWG PCOCC Single Crystal (Douglas Connection)
When I was young, I was Superman but now that old age has gotten the best of me I'm only Batman -
Im using a yamaha rx v671. So you think it will sound great with m70 as rears? Sorry im new to HTSpeakers Polk Monitor 70's (Cherry) Cs2 (Black)
TV Samsung 46" LED
Interconnects MIT Terminator 4-Emotiva Speaker Cables, Audioquest HDMI -
You will be fine with the rears as M70's. Not to be critical, but you have 3 threads open with the same exact question in each. You will get a lot better response by just posting once and letting everyone respond in regards with the information given.
I'd love to have some towers for rears, but the height isn't quite right for my needs. But if you can get by with it, by all means - go for it. Just keep in mind, unless you listen to music in a 5.1 stereo-type mode, the larger speakers will probably be overkill. Surrounds don't have the same demands as the front soundstage would. But as far as placement goes, I'd prefer towers over stands any day.65" Sony X900 (XBR-65X900E)
Pioneer Elite SC-37
Polk Monitor 70's (2)
Polk Monitor 40's (4)
Polk Monitor CS2
Polk DSW Pro 660wi
Oppo BDP-93
Squeezebox Duet
Belkin PureAV PF60
Dish Network "The Hoppa" -
I wouldn't use towers for rear surrounds if your not running an extrnal amplifier. By running towers on the rear your just taking away from your front sound stage.AVR: Onkyo Tx-NR808
Rear: FXI A4
Sub: Polk DSW Pro 660wi
TV: LG Infinia 50PX950 3D
IC: AudioQuest Black Mamba II -
I second not using towers as rears. It is harder to place them correctly and your receiver is not very powerful, and will not do the best of a job driving 4 towers. Also, m60s would be a waste in that role, as you will never really hear that bottom driver. If you are dead set on towers for surrounds go with m50s, they are easier to drive.Living Room 7.1 HT Rig:
M70 | CS2 | M60 | Atrium5 - Surr. | SUB - Emotiva ULTRA12 + Tara Labs sub cable | Pioneer Elite VSX-52 | Parasound HCAs 1000A | Sony BDP-S790 | Belkin PureAV PF60 | MIT Exp2 Wires
Bedroom 5.0 HT Rig (Music/Movies/Gaming) :
LSi9 | LsiC | Lsi/fx | Marantz SR7002 | NAD T955 | Sony BDP-S360 | Belkin PureAV PF30 | AQ Blue Racer II ICs & AQ Type 4 wires | PS3 -
Save a bunch of cash and go with Monitor 30's. They have keyhole mounts and are more than adequate for surrounds. I had Monitor 40's and they were kinda overkill for HT. I also used a set of R50 towers at one point and they didnt sound as good as the Monitor 40's for reasons of placement.
If I had it to do over I would have gotten Monitor 30's for surrounds (and 2 sets for 7.1) rather than the Monitor 40's."....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963) -
Spend the cash and get some bi pole / Di pole surround speakers.AVR: Onkyo Tx-NR808
Rear: FXI A4
Thanks for the help everyone. Ill go with bi pole/ di pole.Speakers Polk Monitor 70's (Cherry) Cs2 (Black)
TV Samsung 46" LED
I purchased a 7.1 set of Monitor speakers. 70s/CS2 up front with the 60s as side surround and the 40s as back surrounds. I tried it setup quite a few different ways and almost always decided I liked the 40s better as surrounds than the 60s. The 40s seem to go lower with less power even though they have fewer woofers. I believe the rear port has something to do with that. Additionally, the surround speakers always sounded better when positioned higher up than I would feel safe putting a pair of 60s. Both the 40s and 60s were a great match for the 70/CS2 front sound stage, and I could see both working out great depending on your room setup.
I have never experimented with di-pole speakers so I cannot compare them to the Monitor line -
Apparently my receiver doesn't support all of that. I have a yamaha rx v671. Can you recommend any av receiver. I also think my yamaha dont support external amplifierSpeakers Polk Monitor 70's (Cherry) Cs2 (Black)
TV Samsung 46" LED
Onkyo TX-NR70x and up have pre outs. I am sure the pioneer guys will chime in as well. The Onkyo TX-NR709 can be bought for $499 from accessories4less.com . It is a refurb but you can purchase a 5 year warrenty for $50 bucks.
http://www.accessories4less.com/make-a-store/item/ONKTXNR709/Onkyo-TX-NR709-7.2-Channel-3-D-Ready-Network-A/V-Receiver/1.htmlAVR: Onkyo Tx-NR808
Rear: FXI A4
Thank you everyone for the help. appreciated. I'll be definitely upgrade my av receiver so i can get full potential with my m70. Even though with yammy 671 with music sounds greatSpeakers Polk Monitor 70's (Cherry) Cs2 (Black)
TV Samsung 46" LED
There's a lot of good advice here, and you'll be happier when you feed more power to the M70's. The difference will be noticeable. I was happy with a low-end receiver on M50's and M60's, but needed more when I jumped up to the M70's. For home theater, using those di-poles will be great. Music is intended for stereo sound, so your front R&L speakers are all you need to worry about for that.
I finally stopped changing and modifying my home theater recently, with four M70's for my front and rear surrounds. I know that some of you think tower speakers for the rear isn't necessary, and that is true in most cases, but most of my time is spent gaming. It's perfect for that, as I get an even, balanced tone coming from every speaker when combined with my XPA-5. Before I had all identical tower speakers, I could notice a difference in how games sounded depending on the direction. Running all of the same speaker, everything sounds fluid and seamless now.AVR: Onkyo TX-NR808
Amp: Emotiva XPA-5 200 watts x 5
Fronts: Polk Monitor 70 Series II
Center: Polk CS2 Series II
Surrounds: Polk Monitor 70 Series II
Sub: HSU VTF-2 MK4
HDTV: 73" Mitsubishi DLP-73740 3D-ready
PS3, 2x XBOX 360, Wii U, Gaming PC.
