IXOS 856 bi ample non terminated cables two 10' foot and one 4', 60.00 Shipped
logo896
Just going in a different direction, this is killer speaker cable. I believe its made in the UK and sells for 15.00 a foot. Basically they separate the positive and negative and a third isolation line and then braid them. This wire is bi ample so it has this done twice. IXOS has won them countless awards, and I use a lot of their products with high satisfaction. Appearing as thick as a garden hose, I found it really brought my RTI 12's and LSI's to life.
Here is the manufacturer on the wire.
PayPal preferred 60.00 bucks shipped to the lower 48.
XHS856 Bi/Single Wire
Gamma Geometry? 11AWG + 13AWG
Patented Gamma Geometry? improves musical clarity and dynamics
High Grade PC-OFC (Pure Crystal Oxygen-Free Copper) conductors significantly improve audio integrity and detail
Individual high and low frequency conductors for detailed performance
Low inductance, capacitance and resistance design ensures smooth highs, authoritative bass, wide soundstage and focused image
Versatile design allows for either Bi-Wired or Single-Wired configuration
Single-wired (combining 1-11AWG + 1-13AWG is equivalent to 9AWG)
http://ixos.co.uk/us/ixos-search-detail.asp?Keyword=xhs856&PROID=111&Category=5&SubCat=12
I have bought perfect score on adiogon (45) and am awaiting on the mail to finish my other sales on this forum, so please buy with confidence.
Attachment not found.
Post edited by logo896 on
I for one have had an EXCELLENT experience dealing with Logan.
I have talked with him every since!
Great guy to talk with, and has been a man of his word from the get go!:cheesygrin:Testing
Testing
Testing -
Hello i`m interested in the speaker cables.
Have a question: is there a chance to just use banana plugs on them but not for bi-wiring or bi-amping, just 2 plugs on the amp side and 2 plugs on the speaker side?
I`m planing to use them with older denon pre/pro and dahlquists dqm-9c.
Thanks for answer and help. -
Yes, you would just twist the positives together and the negatives together- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Sale pending
I just got an E check from another member in a PM so they are pretty much sold already. To answer you can double this wire and make it 9 gauge yes with plugs like your talking about. I have have never bought from this sight, but here is a link to the same as my wire for a good deal.
http://www.accessories4less.com/make-a-store/item/IXOSXHS856/Ixos-XHS856-Bi/Single-Wire-Gamma-Geometry-11AWG-13AWG-Foot/1.html
