2 line phone adapter
fbm211
fbm211 Posts: 1,488
edited December 2011 in DIY, Mods & Tweaks
Anyone ever hook up 2 seperate lines to a single phone jack??
Is it best to buy one of those 2 line phone adapters or get a dual jack and wire it myself using the red and green wires for line1 and yellow and black for line2?
SDA-2BTL with custom IC
Harman Kardon T-55c TT
DH LABS REVELATIONS ICs-amps
Revelation Audio Labs Paradise cryo-silver ICs-Source to pre
Post edited by fbm211 on
  • zane77
    zane77 Posts: 1,696
    Depends on if you are going to use a dual line phone or two seperate phones
    Two Channel
  • fbm211
    fbm211 Posts: 1,488
    2 credit card terminals into line 1 and an ATM and phone into line 2.Line 2 will also have DSL service provided.
  • CoolJazz
    CoolJazz Posts: 572
    The telco standard wiring when putting two lines in is as you quoted, red-green for pair 1 and yellow-black for pair 2.
    If you are trying to get the lines to a location already wired with typical dual pair wire, then certainly no reason to use both pair to get to an area. The two to one splitter you mentioned is typically used to get a dual line split out to a regular single line phone. An alternate would be to split the wire apart and feed one jack plate with one of the lines and another plate with the second line. You could terminate both in the first plate and just add a jumper over to the second one too.
    Personally, I'd avoid those dual line break out adapters if visable or in a location where the lines might get pulled on much. Labeling for someone else could enter what you think is the clearer way too.
    How you wire out is really up to you and what exists already or you want to do.
    CJ
    A so called science type proudly says... "I do realize that I would fool myself all the time, about listening conclusions and many other observations, if I did listen before buying. That’s why I don’t, I bought all of my current gear based on technical parameters alone, such as specs and measurements."
    More amazing Internet Science Pink Panther wisdom..."My DAC has since been upgraded from Mark Levinson to Topping."
