Need advice on speakers for a sony xplod CD Receiver-WX-GT77UI
breathslayer
Ive a Sony Xplod CD Receiver-WX-GT77UI and im yet to decide which speakers i should go for. I prefer d brands jbl, kenwood, pioneer and Rockford Fosgate. I dnt hav a parcel tray in d rear and d cars a hatchback, means short of boot space. So, i intend to install d speakers in d 4 doors. d size is 6 inch round. Also, ive heard dt only 1 set of frnt speakers is better dn 2 sets. is dt ryt?
Kindly Advice.
Kindly Advice.
Post edited by breathslayer on
Kindly advice, learn to write. You aren't texting your buds.If you can't hear a difference, don't waste your money.
Welcome to Club Polk.
I'm sorry, you need to please reword your ENTIRE post, as it makes absolutely no sense.
Did you type that on your phone with auto correct off? Replacing "the" with "d" is in a word, ghetto.Main Surround -
Den - Rotel RSP-1068 / Threshold CAS-2 / Boston VR-M60 / BDP-05FD -
Well all the brands you listed are good brands. It depeneds on what you like, and what sounds best to you. Also if you dont have any back speakers at all then dont worry about them. All you need to begin with is the front speakers, then the sub.. Other than that you should be fine. Do some listing to each on of the speakers if you can, and make your choice from there. In addition I agree with the other people about the grammer, but out of general respect for you, and me I will not rubb it in your face like the other two. That is just disrespectful, but dont be discourged by it, that is just some people. They are however very knowledgeable about this stuff, so keep the questions coming, but just try use better grammer if you can.
Thanks.2006 Prerunner Access Cab
5 Speed 4 cycl 2wd
Audio:
Pioneer P860 Head Unit
Polk Audio MM6501
Alpine PDX F-6
Two SR124(SVC)
Alpine PDX M12
Kinetik HC2000 battery and Sleeve
200 Amp Mean Green High Output Alternator
Need a DJ, photobooth, or both for rent?
http://photoboothdallas.org -
Thanks.[/QUOTE]
There was no disrespect meant or implied. You said the same thing but made a much bigger fuss of it than we did.If you can't hear a difference, don't waste your money. -
The brands that you have listed are not bad, you could do better for the money. I would suggest zapco ppi orion and older phoenix gold. The used market is always great. Also once I get 100a posts I have a w7 jl audio and amp for sale.
