Need help BAD, first system
kettlecorn
kettlecorn Posts: 7
hey all,
I am putting together my first audio system ever for my room and it is fun but also very confusing. (Itll be 2.1)
I bought polk audio monitor 30 series II bookshelf speakers for my room and also a Polk Audio PSW10 subwoofer. I have a Denon AVR-2800 receiver.
I am hooking my sub and speakers by "speaker level" connection.
My front LEFT/RIGHT go into the sub's speaker OUT, and the sub's speaker IN is connected to my receiver's speaker OUT.
The reason why I did this is because of the stupidest reason ever. I bought this receiver used and it doesnt' have a remote. There's no replacement remotes unless I want to spend $100 which is very expensive and I could just get another receiver, and I tried a universal remote from Logitech Harmony and it doesn't work. Basically, I NEED the original remote for 1 freaking button, "System SETUP". This will allow me to turn subwoofer to "Yes" and change my speaker size to "Small" so I can use the receiver's subwoofer out/LFE out port. But since I don't have a remote, it's stuck on "Large speakers" and subwoofer "NO". So I need to connect everything with what they call "speaker level" connection.
It's just for my room and my room is not that big. My question is, can I bi-wire my Polk Monitor 30 speakers to my sub's speaker OUT connections like I would to my receiver (if I didn't have a sub to connect)? Or should I just stick with a traditional connection?
Since I can't get into LFE mode, I may be willing to spend at MAX $100 to bypass this ridiculous issue by getting another amp, or some pre/pro amp and use the receiver with "external IN" mode. Anyone have any suggestions?
Any help appreciated...
Post edited by kettlecorn on
  • PSOVLSK
    PSOVLSK Posts: 5,379
    edited November 2011
    That stinks. I'm surprised the Harmony didn't work.
    I don't think you can bi-wire, but I'd stick with the traditional connection regardless.
  • dudeinaroom
    dudeinaroom Posts: 3,609
    Did you try looking up remote codes for the harmony that are for that receiver? Welcome to club polk. If I had a faster intrnet connection I'd look it up for you...sorry I don't
  • kettlecorn
    kettlecorn Posts: 7
    Yeah, i kind fixed some of the problem. Well most. The harmony has the Denon AVR-2800 in the database so basic things like volume, power, input, etc. that kind of stuff works. However, it doesn't have System setup which is the 1 freaking button I need. lol
    I'm not sure if there are certain "codes" that you can program into the Harmony but if so, that could be hopeful.
    But to address the subwoofer connection, I just went with a speaker level connection. I figured this receiver is not going to let me change the settings to allow for the subOUT to work so I hooked it up by connecting speaker wires from the receiverOUT to the speakerIN (on the sub) and connecting both Polk monitor 30s to the speakerOUT on the sub.
    When I did this, the sound was really bad. It was not fully there very muffled and bassy. Completely different than when I had them connected bi-wire to my receiver without the sub. I tried changing the connection on the Monitor 30 speakers to the bottom ones (there top L/R and then there's bottom L/R) and I realized what it was. I read somewhere that the top connections are for the tweeters and highs and the bottom is for the bass. It seems like a traditional single connection for these speakers don't work well. I mean, if that sound passes as good then there's a problem. But I took a gamble and did the same bi-wire connection I had done between the receiver/speakers onto the new connections between the speakers and the speaker-subOUT. and what do you know? Freaking amazing sound. With bass. :) Me happy.
    Wish I had the ability to mess with the bass and treble and whatnot through the receiver but oh well.
    The other issue is that the volume is pretty loud. Even at -60db which is the lowest my receiver goes to, it's nothing that's whisper quiet. Can't play games at that level at night. Probably because the double amplification?
  • danger boy
    danger boy Posts: 15,722
    look on Ebay for a original remote.. i bet you find one there..
    I like your user ID name. :cheesygrin:
    PolkFest 2012, who's going>?
  • kettlecorn
    kettlecorn Posts: 7
    edited December 2011
    haha $100!
    damnnnnn
    lol thanks
  • Glowrdr
    Glowrdr Posts: 1,103
    I've found some "replacement" remotes that at least have the button you are looking for. Think it was $50-60? Let me know if you were interested.
    Also, not sure if you said you still had the harmony or not, but check out www.remotecentral.com - this is the Club Polk of remotes. lol
    65" Sony X900 (XBR-65X900E)
    Pioneer Elite SC-37
    Polk Monitor 70's (2)
    Polk Monitor 40's (4)
    Polk Monitor CS2
    Polk DSW Pro 660wi
    Oppo BDP-93
    Squeezebox Duet
    Belkin PureAV PF60
    Dish Network "The Hoppa"
  • kettlecorn
    kettlecorn Posts: 7
    Got it to work! Complete!!!
    thanks for the help.
  • dudeinaroom
  • detroitHOOLIGAN
    detroitHOOLIGAN Posts: 30
    all my Denon remotes have worked on all my recent (manufactured within the last ten years) receivers and even one I repaired for a customer a few weeks back. When you get a few dollars go buy a new denon, use its remote and fix your setup, even better use the remote to program the menu function on a new universal,and return the unit. lastly in my living room I have a cheaper AR universal remote from bestbuy and it performs every function on my Denon, not the highest quality remote and eats batteries every 10 days, but it is an option.
  • Glowrdr
    When you get a few dollars go buy a new denon, use its remote and .... return the unit.
    No wonder why we can't return anything without a restocking fee, or buy an open box without missing all kinds of accessories.
    Pioneer Elite SC-37
    Polk Monitor CS2
    Polk DSW Pro 660wi
    Oppo BDP-93
    Squeezebox Duet
    Belkin PureAV PF60
  • dudeinaroom
    Screen name says it all. I know I used to live down there and you could not pay me to move back.
