non SVS sub question
phoneisbusy
phoneisbusy Posts: 867
Okay, I'm jealous! The church organ music thread results has me droolin' but a new sub is not in the cards. I do have a generic $200 sub that a friend hooked me up it. For the price, I believe it's good value. The cabinet is well made and heavy as hell.
It's a 12" woofer, port on the bottom with a 150W amp and they gave me a remote (well, I actually don't use it).
I've got a SPL meter on the way so I can measure/benchmark properly and I have Dr. Spec's handy spreadsheet.
I downloaded the sine waves from 100 - 10 Hz and tried it last night. My question is what is reasonable performance from a sub?
It plays the tones from 100 down to 31.5 Hz very loud and clear. The volume begins dipping significantly at 25 Hz (it's subjectly about half as loud) and you can't hear anything below 25 hz although some knick-knacks by the sub rattle.
Just curious if there are any tips I should be aware of when I try and measure the SPL this weekend?
Dave
Time is the best teacher. Unfortunately it kills all its students.
Post edited by phoneisbusy on
  • Dr. Spec
    Dr. Spec Posts: 3,780
    edited September 2003
    Advice?
    Don't play the tones too loud or you will fry the VC on the driver. I use about 80 dB at 100 Hz as a starting point.
    And the RS meter needs correction factors. My spreadsheet probably has them, but I have a few versions floating around so make sure the one you have has the RS meter correction factors.
    Based on what you said, the sub is probably tuned at around 35 Hz, and with room gain you will see extension to around 32 Hz. Below that it will drop off at 24 dB/octave (i.e., pretty steeply). So your subjective impressions about a significant loss of output at 25 Hz make sense.
    The organ recordings (if you have them) have 16 Hz content, and you probably won't feel anything from the sub at those ultra deep frequencies.
    Doc
    SVS
  • Pauly
    Pauly Posts: 4,519
    can i get a copy that RS Spl meter SS?
    paul_pelletier@verizon.net
    Life without music would
  • phoneisbusy
    Originally posted by Dr. Spec
    Advice?
    Doc
    As always, thanks for the suggestions Doc.
    Is 35Hz a typical tuning point for subs? Just curious as to how this sub stacks up to typical low/mid range consumer subs (no illusions of this kicking any sub's butt here... ;) ).
    I've head of Polkster's plugging the ports to get a bit lower extension and/or using granite plates under subs on carpet. Are these tweaks applicable to most subs?
    regards
    Dave
  • Dr. Spec
    regards
    Dave
    Sure...this sounds like a PSW450 type sub - 12" driver, 150 watts, ported. 35 Hz is a pretty standard tune for an entry level sub like this.
    You only have one port though, so I wouldn't recommend plugging it - the sub might not respond properly because the T/S parameters of the driver might not be appropriate for an acoustic suspension application.
    The slab under the sub is if you have a wooden floor that booms. The slab can help decouple the sub from the floor and reduce boom. The A/C unit concrete pad for less than $10 works well.
    SVS
  • gatemplin
    gatemplin Posts: 1,595
    For what its worth, I tried plugging my 202 and wasn't an improvement. It sounded like it was straining.
    Graham
