Blue jean cables speaker wire
fjross
fjross Posts: 183
Has anybody had any dealings with Blue Jean cable speaker wire?
thanks
Mcintosh MC-501 mono blocks
Mcintosh C-45
Mcintosh MVP-871
PS AUDIO AV5000
MIT 3.3 Shotgun biwire speaker interface
MIT 3.3 Shotgun XLR interconnects
Polk 2.3TL's Gimpod boards/F-1 modded crossovers/dynamat/JB weld/Larry's rings/Blackhole 5 strips
Polk 3.1 TL's mint/stock (purchased new)
Polk SDA-2's
Post edited by fjross on
  • Glowrdr
    Glowrdr Posts: 1,103
    edited November 2011
    I personally never have, but they are a widely praised company around here. Sounds like if you want cheap, goto Monoprice. If you want to experiment with the next step up in quality, BJC is one of the places to look. After that, you start getting into some crazy $200+ cables (not very experimentation friendly if you ask me)
    65" Sony X900 (XBR-65X900E)
    Pioneer Elite SC-37
    Polk Monitor 70's (2)
    Polk Monitor 40's (4)
    Polk Monitor CS2
    Polk DSW Pro 660wi
    Oppo BDP-93
    Squeezebox Duet
    Belkin PureAV PF60
    Dish Network "The Hoppa"
  • fjross
    fjross Posts: 183
    Thanks for the reply, I also have heard some high praising of there cables from some high end forums.
    Mcintosh C-45
    Mcintosh MVP-871
    PS AUDIO AV5000
    Polk SDA-2's
  • fjross
    fjross Posts: 183
    I will let you know how I make out, I think I may buy a set to relocate the stereo equipment for the Xmas.
    Mcintosh C-45
    Mcintosh MVP-871
    PS AUDIO AV5000
    Polk SDA-2's
  • Glowrdr
    Update us for sure. Right now I've got a random mis-mash of assorted cables that I've aquired over the past 10 years or so. Some are Monster i1000's, others are $10 JVC cables from Target.
    I'm going to be moving all of the stuff from my audio tower, and just using the shelves on my TV stand so get rid of all the cables strung across my wall. Probably the best time to just get all new cables and finally have true cable management. I'm sure that's one purchase I won't have any problems getting the wife on board with.
    Pioneer Elite SC-37
    Polk Monitor CS2
    Polk DSW Pro 660wi
    Oppo BDP-93
    Squeezebox Duet
    Belkin PureAV PF60
  • cfrizz
    cfrizz Posts: 13,415
    BJC is a great company that makes good products at reasonable prices. All of my IC's except for my sub cables are from BJC. They ship very fast and have good CS.
    Welcome to Club Polk Fjross!
  • codyc1ark
    codyc1ark Posts: 2,539
    cfrizz wrote: »
    +1 to that, I just upgraded my pre to amp ic's and speaker cable to the canare and I'm very happy with my results, I'm sure I'll use them again!
    Good luck and welcome to CP!
  • BlueFox
    BlueFox Posts: 15,251
    I needed a special cable with RCA to BNC to go between my iTransport and Benchmark DAC, and they shipped it same day.
  • breal74
    breal74 Posts: 324
    BJC puts out a great product with great customer service, fast shipping and most important, I think, is the try to use American made products as much as possible.
