Finally got my ears on some 24/96 material
steveinaz
steveinaz Posts: 19,545
edited November 2011 in 2 Channel Audio
Outstanding. Never had a source that could do 24/96 before the Touch, so I finally downloaded a flac concerto ala Mozart. Wow. It's nice to see what the Benchmark DAC is truly capable of with this hi-res content. Most significant improvement? Dynamic range struck me first--from whispering violins, to huge crescendos; never heard this much range. Of course the realism is off the charts.
Post edited by steveinaz on
    heiney9 Posts: 25,421
    So you compared the exact same version of the std Mozart file?
  • steveinaz
    No, I just downloaded the 24/96 version from a site that had some free hi-res downloads available. It's about a 5 minute piece (violin concerto #9 or some-such?), 175MB in flac form.
    Not to be an a$$, but how do you know it's better than the original non hi-rez version? If you don't compare the two to each other I am not sure you really know. Not trying to bust your balls.
    tonyb Posts: 33,068
    Broch, Steve never said it was better or worse than a non hi-rez version, he's just commenting on what he likes about the 24/96 file is all.
  • Face
    Face Posts: 14,340
    And I agree with Brock, it's not a real comparison.
    tonyb wrote: »
    Read between the lines.
    Again, not trying to bust Steve's balls. He has always been very persnickety about listening and comparing so that's why I asked. I am considering hi-rez but I'm not entirely sold on it being night and day different. To be fair I haven't listened to a lot of hi-rez files.
  • FTGV
    FTGV Posts: 3,650
    heiney9 wrote: »
    If it's from someone like 2L it may be natively 24/96 with no 16/44 equivalent?.In fact if it were merely upsampled 16/44 then it would not be true hi rez.
    FTGV wrote: »
    That is true and I am trying to be a catalyst for discussion, not busting Steve's nads as we are mostly on the same page.
    I am just trying to figure out what the "constant" is from which he based his post. Steve, typically is very thorough about comparative listening.
  • markmarc
    markmarc Posts: 2,309
    Steve, name the site please.
    Former Staff Member TONEAudio
    2 Ch. System
  • AsSiMiLaTeD
    AsSiMiLaTeD Posts: 11,728
    If he's hearing things that he's never heard before in any recording then I'd say the conclusion is still valid
    Lol..........that makes no sense at all. Every single recording made sounds different.
  • falconcry72
    falconcry72 Posts: 3,580
    heiney9 wrote: »
    Agreed.
    For the record, I'm with H9 on this one.:wink:
  • jonicont
    jonicont Posts: 281
    Figured I'd give 24/96 a try and bought some things from HD Tracks on Thanksgiving.
    First up Allmans Fillmore East. This one had the most dramatic improvement from the cd. Really, it was like taking foam earplugs out. It's an old cd and not any type of audiophile copy. The separation between and clarity of the instruments was what was most noticeable. Guitars were bright and up front, seemed buried on the cd.
    Next was Talking Heads--Remain in Light. Again a significant difference from the cd. Very clear separation of the voices. The bass was cleaner and deeper and jumped out of the speakers on the A-B switch ( volumes were equal)
    Finally Dark Side of the Moon. 30th anniversary remastered vinyl and 24/96 Flac. The 24/96 had great bass, separation, soundstage. It sounded fantastic. Still ain't vinyl though, sorry folks.
    24/96 from the Squeezebox. Cd's were in a Sony 5 cd carousel. Both hooked to the dac with optical
    DynaudIo Evoke 30, VPI Prime, Soundsmith Zephyr MKIII, PS audio Stellar phono pre, McCormack DNA 0.5 Gold, ARC LS-17se, Eversolo dmp A8, MIT AVT MA ic’s and speaker cables, ps audio stellar power plant 3
  • CoolJazz
    CoolJazz Posts: 572
    I've been doing 24/96 type stuff, mostly from HDTracks, for a while now. And I do have direct comparison stuff. I love it very much and it is a pretty big step as far as I'm concerned! Chicago II is something a lot of people should be familar with for instance. Wow...very good at high rez! Going back to redbook makes the music kind of coarse sounding after you've been listening to high rez for a while.
    A good clean vinyl can still be better in some ways, but the high rez in other. You can hear the difference when you go to vinyl or tape, even out of the sweet spot. Best I could put it in words would be more relaxed or natural. But I think high rez is narrowing the gap by a big step!
    I've purchased Cirlinca, and only burn to DVD-A, never play from a PC. I've found this software to be pretty straight forward and not fiddly...
    http://www.cirlinca.com/
    CJ
    A so called science type proudly says... "I do realize that I would fool myself all the time, about listening conclusions and many other observations, if I did listen before buying. That’s why I don’t, I bought all of my current gear based on technical parameters alone, such as specs and measurements."
    More amazing Internet Science Pink Panther wisdom..."My DAC has since been upgraded from Mark Levinson to Topping."
  • steveinaz
    Correct, not meant be a a vs b comment, just commenting on how nice the 24/96 sounds.
  • steveinaz
    markmarc wrote: »
    Here you go Mark: http://www.2l.no/hires/index.html
    I downloaded the very first one.
  • steveinaz
    Brock
    The only comparison I can make would against my existing CD library--only my finest DDD 24bit dirived classical CD's come close, and they still don't have the Dynamic Range swing, nor the air or overall smoothness. Download it and check it out--it's pretty awesome.
  • steveinaz
    You guys are intense. Should I have made a video of the moment?...LOL relax and enjoy the music.
  • audiocr381ve
    audiocr381ve Posts: 2,588
    CoolJazz wrote: »
    CJ
    My experience is the same. Hi-rez sounded better in my system.
  • AsSiMiLaTeD
    heiney9 wrote: »
    LOL, uh yes it makes perfect sense, which is also why his statement below of "The only comparison I can make would against my existing CD library--only my finest DDD 24bit dirived classical CD's come close, and they still don't have the Dynamic Range swing, nor the air or overall smoothness" is also valid.
    Yes every recording ever made sounds different, but if I'm hearing something like better dynamic range in a hi-rez recording that I've never heard in another recording, then it's probably safe to attribute that to the technology. Sure, it 'could' be something specific to the recording, but given steve's history and good selection of music, if he's hearing something in this first hi-rez recording that he's not heard before, then it's safe to say it's the tech, not the specific recording.
  • AsSiMiLaTeD
    Steve, check out hdtracks then. I know you're familiar with the Steely Dan material, the high rez version of Gaucho is outstanding.
  • steveinaz
    Oh yes, definitely--as soon as I get this ripping chore done. I'm about 70% finished. I'm also looking at "Rumors" and "Frampton comes alive" in 24/96. I'll be a regular customer there, soon.
  • xsmi
    xsmi Posts: 1,801
    Are SACD's in this format?
    2-channelBelles 22A Pre, Emotiva XPA-2 Gen 2, Marantz SA8005, Pro-Ject RPM-10 Turntable, Pro-Ject Phono Box DS3B, Polk Audio Legend L800's, AudioQuest Cable throughout.
  • audiocr381ve
    xsmi wrote: »
    Not necessarily, although SACD's have more dynamic and frequency range than red book. I'm sure someone can explain it better.
    http://en.wikipedia.org/wiki/Super_Audio_CD
  • BlueFox
    BlueFox Posts: 15,251
    xsmi wrote: »
    Mostly no, as they are a different animal. However, I believe the files that were used to create the SACD Rolling Stones CDs are the ones offered on HD Tracks for download in 192/24 format.
  • unc2701
    unc2701 Posts: 3,587
    BlueFox wrote: »
    Almost all old recordings offered on SACD have passed through some form of PCM. If a recording is available on DVD-A and SACD, buy the DVD-A, because it's gone through one less conversion.
    For new recordings, and not classical, odds are it's gone through PCM, too. Editing DSD is a ****, so unless they're pretty much going straight to disc, it'll be high-rez PCM, then get dumped to SACD.
    I have done a 1:1 comparison of CD vs High-rez DVD-A and SACD; I was pretty shocked at the difference. First high-rez disc I got was NIN's Downward Spiral. On the radio, you can't hear this at, but during the 8 measures of drum beat before the vocals start on "Closer", there's a faint melody going in the background. On the CD, this breaks up slightly with each loud drumbeat; on high-rez, there's no breakup at all. If you ever want to sell someone on the importance of the higher sample rate, that's one recording anyone can hear it immediately.
    Backburner:Krell KAV-300i
