Parametric Equalizer
mara5
mara5 Posts: 54
edited November 2011 in Electronics
Can anyone advise what it is, and better yet explain what it does? Thx:confused:
Post edited by mara5 on
  • inspiredsports
    inspiredsports Posts: 5,502
    Basically a bunch of potentiometers [variable resistors] otherwise know as volume controls, each based around a frequency band (with the use of capacitors), that allow you to boost or repress sound signal levels at various frequencies throughout the audible range.
    Let's say you have a room (or recording, or SL2000 tweeter in your system) that seems too "bright" at 12,000Hz. Find the control for that frequency range/parameter (therefore, parametric) and turn it down a bit.
    Maybe your room soaks up low bass. Find the the control for that range of frequencies and turn it up a bit, etc., etc.
    A balanced system/room should produce all frequencies at an equal level given equal input power (flat response), but that's hard to achieve in the real world. An equalizer is an attempt to boost or soften the frequencies not being reproduced equally by your speakers and electronically create that flat response curve.
    The problem is all of those components/controls in the equalizer add TONS of noise to your music unless you spend what a top recording studio would spend for an equalizer.
    Conrad Johnson PV-5 w/mods
    MF x-DAC V8, HAInfo NG27
    NAD SS rigs w/mods
    GIK panels
  • steveinaz
    steveinaz Posts: 19,546
    Parametrics not only allow frequency adjustment, but also the bandwidth affected (narrow/wide); where graphic eq's only adjust frequency levels, while also causing adjoining frequencies to be affected, with no control to minimize this.
  • mara5
    mara5 Posts: 54
    Thank-you both.
  • steveinaz
    No problem--parametrics let you zero in on a particular frequency, if you need to, graphic eq's don't have this flexability.
