SDA SRS 1.2 VS. SDA SRStl's
fjross
Is there any way to tell a visual differance between the 1.2 and 1.2tl's with or without grills removed? Do you think a Mac. 352 would be enough to power these speakers?
Mcintosh MC-501 mono blocks
Mcintosh C-45
Mcintosh MVP-871
PS AUDIO AV5000
MIT 3.3 Shotgun biwire speaker interface
MIT 3.3 Shotgun XLR interconnects
Polk 2.3TL's Gimpod boards/F-1 modded crossovers/dynamat/JB weld/Larry's rings/Blackhole 5 strips
Polk 3.1 TL's mint/stock (purchased new)
Polk SDA-2's
Mcintosh C-45
Mcintosh MVP-871
PS AUDIO AV5000
Polk SDA-2's
Post edited by fjross on
The 1.2 uses SL2000 or RD0194-1 tweeters, the 1.2TL uses SL3000 or RD0198-1 tweeters.
Yeah, that amp will drive them.Political Correctness'.........defined
President of Club Polk -
I think the sl-3000 tweeter is darker than the sl-2000 tweeter
You really need to get a look at the tweeters with the grilles off, but even then it may be tough if tweeters have been replaced.
Can you post images of the tweeters, crossover covers, binding posts and serial number plates?VTL ST50 w/mods / RCA6L6GC / TlfnknECC801S
Conrad Johnson PV-5 w/mods
MF x-DAC V8, HAInfo NG27
NAD SS rigs w/mods
GIK panels -
It's tricky because I have 1.2tl's that don't have the TL on the back of them. If the tweets were changed ask if you could remove a tweet. The SL3000's have a fat and a thin connector that plugs in the back of the tweets. The Sl2000 are both thin connectors. My SRS 1.2's are also a much lighter oak color than 1.2tl's I used to own. Both of my 1.2tl's I own now are the walnut shade. Does anyone know when Polk changed shades of there oak color. My SRS 2's, 1.2's and CRS+'s are all the same light color oak. My old 1.2t's and current 3.1tl's are a darker shade of oak. Maybe that is one way to easily tell the 1.2 from the 1.2tl's.Polk HT system 1: LSIC, LSI25 mains, LSI F/X rears, Lsi F/X rear centers,
Yamaha RX-V2500 System, Carver A753 3 channel amp.
Polk HT system 2: , SRT system with f/x 1,000's rear speakers on 7.1 system currently using Onkyo TX-RZ820 receiver, powered by Sunfire Grand Theater amp
Polk Speaker collection: SDA SRS 1.2tl x 2, SRT system, SDA SRS 2 P/B, SDA 2A, SDA 1C Studio, SDA CRS+, Monitor 7B & 4, SRS 3.1tl, RTA 15tl, LS90, LSI 9 -
Polk offered the light oak, medium oak and walnut on most of the SDA line, so that is not a way to tell the model.Political Correctness'.........defined
Was away for the weekend, I just wanted to thank everyone for your replies.Mcintosh MC-501 mono blocks
Mcintosh C-45
Mcintosh MVP-871
PS AUDIO AV5000
Polk SDA-2's
