what's in a watt
leftwinger57
leftwinger57 Posts: 2,917
edited November 2011 in Electronics
Hi guys, This question seems to be to hot topic of the month here w/loads of people gifting and getting their presents and all are asking what avr should they go for. For me I was kinda of disappointed w/ the output of my Yamaha RX-V665 which I clipped on more than a few occassions.Finallly after all advice on here and that the 90wtts per really isn't, I did go fiirst w/ preouts w/ an Adcom then to a totally seperate 2 chl system. But here's what I do not for life of me understand,you put a McIntosh 2100 rated at 105wtts and sure enough that's what you get or better.So is there really a different rating system that the Japanese use to boost their numbers,or as some have said that these are #s w/o any load on them whatsoever....
    VR3 Posts: 29,549
    Current is far more important than wattage. Wattage can be skewed by the amount of distortion you put into it or is it a full 20-20 signal being used or just 1khz? Is it one channel or all channels? Lots of ways to skew the numbers.
    Current though is pretty safe bet if you have 100 watts with 5 amps of current you are probably not going anywhere, but if you have 100 watts with 60 amps of current or so on you have alot of reserve and can probably go a bit further (generically speaking)
    http://sound.westhost.com/amp-basics.htm
    heiney9 Posts: 25,501
    Wattage doesn't really mean anything and you should never use that as a sole determining factor. I'll sound like a broken record to some but I'll say it again. I have 30wpc and it's more "powerful" than any amp I've owned or auditioned. I have yet to find the upper limits of the amp and I have had it pretty loud with some difficult loads.
    VR3 Posts: 29,549
    H9 you obviously must be mistaken...
    I thought you needed 200 watts to just get a speaker cone moving.. :-P
  • Joe08867
    Joe08867 Posts: 3,919
    The problem with Manufacturers ratings is there is no criteria other than what they want to use.
    They don't have to drive a certain type of load to get an accurate reading. They can drive there amps to clip for one millisecond and get 150 watts but when they drive the same load as everyone else the truth comes out.
    You also have to remember that a receiver is running more speakers than a 2ch amplifier. So the power is usually spread across multiple speakers at the same time.
    mhardy6647 Posts: 35,235
    heiney9 wrote: »
    Long story short - I'm with him.
