Do i need a power amplifier
over50
over50 Posts: 201
edited November 2011 in Electronics
I need some advise. My system is listed, would i notice any improvement if i added a 2 or 3 channel amplifier?
My system sounds Good, but on the other hand i have no knowleage when it come to power amps.
Thanks in advance for your input.
Marantz SR 7007
polkaudio RTi10
polkaudio CSi A6
polkaudio RTiA3
B&K ST.3140 Power Amplifier
HSU Research VTF2 MK3
Vizio P65-C1
Panasonic 605 blu ray
Onkyo DS-A4 i-pod Dock
Universal Remote
BDI Icon 9429 TV Stand
Post edited by over50 on
  • nguyendot
    nguyendot Posts: 3,594
    Your receiver is 135w/channel - max. I have the same receiver and it definitely helped when I added a 5 channel amp to it. Your speakers would benefit from more power, but it all depends on what you listen to. You may or may not see a benefit.
    Main Surround -
  • over50
    over50 Posts: 201
    Thanks for the reply. I was either looking at a 2 or 3 channel. My intent would be having the front's and center on the amp.
    Still trying to figure if the 3 channel is worth the extra cost. Thanks again nguydot for the reply post.
    Marantz SR 7007
    polkaudio RTi10
    polkaudio CSi A6
    polkaudio RTiA3
    Vizio P65-C1
    Universal Remote
  • justlord
    justlord Posts: 33
    I love this AVR. It is really a monster at 135-watts. Based on your sig, it appears you're driving a 7.1 surround system. If so, then one important factor to consider is that during some peaks in movies, our system really isn't pushing 135 watts per channel. This AVR is rated at 135 watts per 2 channels driven (check the manual).
    This said, I am in the same quandary as yourself, and considering the 3-channel or 5-channel amps myself. For my speaker purchase in the near future (RTi A6 and RTi A7), I will probably go with the Emotiva XPA-5 over the XPA-3, just for the sakes of having the option of bi-amping my speakers as well. The price difference is about $200 between the two amps, and an even better deal if you can grab one before the holidays are over.
  • over50
    over50 Posts: 201
    Makes sence. I'm kind of thinking the same and checking the Emo web page. I was watching a DVD the other day, had to raise the volumn much higher to achive the same loudness.My AVR is getting pushed to the max. I'm thinking having the fronts and center powered by a seperate power amp at the very least. Thanks for your input.
    Marantz SR 7007
    polkaudio RTi10
    polkaudio CSi A6
    polkaudio RTiA3
    Vizio P65-C1
    Universal Remote
  • gwg_97
    gwg_97 Posts: 332
    No one ever complained about having too much power! A nice 3 or 5 channel amp would make your Rtis sing. With my Yamaha AVR, a 220 watt extrnal amp made a huge dfference! Check out the outlaw black friday secret sale or pick up a good used parasound, carver, etc. You will love it!
    System 1:Nakamichi PA-7Kenwood Basic C2Polk SDA 1C moddedSystem 2:Dynaco ST-70Polk Monitor 5B modded
  • ibewbrother
    ibewbrother Posts: 186
    yes.....you need more power
    "Making life enjoyable through expensive electronics." BillD
    Pioneer Elite SC-57
    M70 series 2 mains
    CS2 center
    M40 surround
    M30 front height
    SVS PB 12 NSD
    Carver TFM-45 (mains)
    Carver A753x (center, surround)
    320GB PS3, 42" Panasonic G10,
    M60's as a Zone 2 off of the Pioneer in the living room
    R.I.P. Onkyo TX-NR807
  • Gadabout
    Gadabout Posts: 1,072
    Well... you certainly don't "Need" more power but you would find out how much more enjoyable it is to be running seperate amps. At a minimum, try and get a 3 channel amp for the mains and center, if your primary use is HT. If you just want to upgrade for music you could get by with a 2 channel amp. You won't regret adding a 3 channel amp to the system.
    There are alot of us at Club Polk that have our AVR's just doing the pre/pro duty. We aren't driving any speakers with them at all. The best thing I did for my HT was added 2 amps to the sytem.
    Scott
    Without music to decorate it, time is just a bunch of boring production deadlines or dates by which bills must be paid. ..... Frank Zappa
  • ibewbrother
    I only drive the M30 heights with the 807.
    Pioneer Elite SC-57
    M70 series 2 mains
    CS2 center
    M40 surround
    M30 front height
    SVS PB 12 NSD
  • jbooker82
    jbooker82 Posts: 1,627
    I would be looking for one. I run a Carver A-753x (250watt x 3) for my RTI A7's and CSI A4. It was a pretty big change in a positive way. I would look for at least a 3 channel if not a 5 or 7.
    AVR: Onkyo Tx-NR808
    Rear: FXI A4
    Sub: Polk DSW Pro 660wi
    TV: LG Infinia 50PX950 3D
    IC: AudioQuest Black Mamba II
  • ibewbrother
    I thought the A-753x was a rare bird.....now it seems everyone has one.....
    O.T. so...does anyone know where I can get some factory handles?
    Pioneer Elite SC-57
    M70 series 2 mains
    CS2 center
    M40 surround
    M30 front height
    SVS PB 12 NSD
  • over50
    over50 Posts: 201
    Thanks for the info. I'm now a strong believer, that a power amp will make a difference. I'm most likely going to buy new amp. Cyber monday maybe i can get a deal . My first choice will be 3 channel for fronts & center.
    Marantz SR 7007
    polkaudio RTi10
    polkaudio CSi A6
    polkaudio RTiA3
    Vizio P65-C1
    Universal Remote
  • ibewbrother
    I don't really know where to start.... you don't need a universal remote...the Onkyo will do everything. It's programmable. The Onkyo 807 also has the Port feature...A.K.A. I-Pod dock. It runs about $20.
    Only thing is.... My 807 runs HOT....burn your fingers HOT.... and that's just driving the heights.
    If you can find a Carver A-753x....That's what you want...250x3..and the three meters up front are unique.
    Good Luck
    Pioneer Elite SC-57
    M70 series 2 mains
    CS2 center
    M40 surround
    M30 front height
    SVS PB 12 NSD
  • jbooker82
    I havent seen very many A-753x come up for sale. The one I bought had been on ebay several times. The guy started out at $900. Each time he relisted it the price would drop. Well when it got down to $600 I couldn't stand it any more. I have only seen one come up for sale on ebay since. It was pretty hammered though.
    The warm carver sound is what I was after. I also like the look of the 3 meters.
    AVR: Onkyo Tx-NR808
    Rear: FXI A4
  • Hawkeye
    Hawkeye Posts: 1,313
    I'll ask you this simple question. Is there something wrong with what you are hearing now? If so, what is it?
    Gordon
    2 Channel -
    Symposium Rollerblocks 2+ (16)Black Diamond Racing Mk 3 pits (8)
  • over50
    over50 Posts: 201
    Besides a Vector Research receiver back in the 60's this is my first system. I've never had a power amp so my point of comparing is not there. That’s why I posted, to get feedback from experience home theater people. After I bought the FX500i I noticed that have to raise the volume on my AVR higher to achieve the same loudness. Other then that, I guess the RTi system sounds OK. I just don't have the experience that the members of this Polk forum have. I also read that under powering a system could cause damage? Wondering if adding more power would give me a noticeable improvement and a worthwhile investment to my system.
    Marantz SR 7007
    polkaudio RTi10
    polkaudio CSi A6
    polkaudio RTiA3
    Vizio P65-C1
    Universal Remote
  • Gadabout
    I know you said you were going to buy new.....
    but let me tempt you.....
    B&K 5 channel amp on Audiogon. Seems like a fair price.
    125 watts from an amplifier is different from the watts you get out of a receiver and B&K amps match up very well with Polk speakers (meaning they seem to tame some of the brightness associated with the RTi line). I'll also be up front and tell you that I'm a big fan of B&K. I'm running 3 of their amps around the house.
    Whatever you decide to get, I'm sure you will enjoy the new amplification in your HT.
    Scott
  • jbooker82
    Sherardp wrote: »
    That sun fire amp is a good deal. Especially since it just got back from a tune up.
    AVR: Onkyo Tx-NR808
    Rear: FXI A4
