wires from terminal block to cone
DracoAmericanus
DracoAmericanus Posts: 112
edited November 2011 in Vintage Speakers
I have noticed on other subs that the silver flexible wires theat connect the terminal block to cone sometimes slap the cone and cause clear distortion, allmost like the voice coil is hitting the back of the structure. has anyone had this problem with the sda drivers? i allways try to make shure there is clearance but was wondering if others have discovered this problem? I either bend the wires out of the way or resolder them so they have more clearance, i think i had this fault with one of my 6509 drivers.
There is no cure....
Luxman M117, SDA SRS 2.3, rear monitor 10, back rear bose 4.2, valodyne sub and 2 Onkyo m-504 amps Onkyo TX-NR709
8mm, 7.62x39mm
Post edited by DracoAmericanus on
  • Joe08867
    Joe08867 Posts: 3,919
    Never had this problem on any of my SDA's unless I was overdriving them. Cut back some on the volume and it should eliminate the issue. I would also check to see if the cabinets are sealed well. Loss of air pressure in the cab would cause excess excursion.
  • inspiredsports
    inspiredsports Posts: 5,501
    Can you post a photo? Also, you first mentioned "subs" and then 6.5" MW6509's; was that just as an example of what part could be the culprit?
    Conrad Johnson PV-5 w/mods
    MF x-DAC V8, HAInfo NG27
    NAD SS rigs w/mods
    GIK panels
    F1nut Posts: 50,761
    It's not the wire leads, that driver is bad and should be replaced.
