Problem with Elemental Design A2-250 subwoofer
This subwoofer fires down and I believe that the actual subwoofer is hitting the floor when it start kicking. It starts to produce a very rattly sound, I believe this to be the enclosure jumping off the ground, because when you push down on the subwoofer, it stops. Is there anything I can use to stop this? I've been told to get 1"x1" blocks of wood and put them under each spike. I don't really like the idea of that. I think it would be ugly.
Post edited by RileyD on
I would get the subwoofer platform that ED sells...
It isolates the subwoofer from the floor and will help it from walking around- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
I'll look into that, but $60 is a bit much just for that pad.
There's no way that driver is hitting the floor, it's clipping. Where do you have the gain set?"He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
The driver is not hitting the floor. If it goes away when you push down then the entire sub is walking across the floor. You will most likely need something like that platform or you can try adding weight to the top of the sub if you really want too.Living Room Rig:D
Rotel RSP-1069/Rotel RMB-1095/Rotel-1072/Polk lsI15's W/modded xoverW/DBsubs/Polk LsiC/lsI7's/Klipsch sub-12"the weak link"/DLP Mitsubishi 65"
Xbox360/PS3/WII
M.Br. setup:)
Emotiva MMC-1/Rotel RMB-1075/Polk BlackStone TL350's/Velodyne SPL1000/Samsung 51" Plasma
Computer Rig:
Rotel RB1050/Tannoy DC4's/Klipsch RW-10d/ImodIpod/HK AVR230 for now....
Headphones-Ultrasone-HFI780's w/LittleDot MK Vamp Portables Panasonic HJE-900's -
Build your own May save 20 bucks...- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
What causes a sub to walk?
It just being able to move so much air, it is exerting enough upward force to essentially pick up the subwoofer and move it, simple as that- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
