Bi-Amp Tsi 500 Speakers
fanisius
fanisius Posts: 8
edited November 2011 in Speakers
I have my Tsi-500 Speakers bi-amped using an Adcom GFA-535L on the top poles and a GFA-545 on the bottom poles. Both amps are sending a signal but I can only get sound from the bottom poles. Nothing from the top. If I connect either amp to the bottom poles I get sound. If I connect either to the top poles I get no sound. I am testing this with a static white noise signal, so shouldn't I hear something from the top poles? Even if is the tweeter? Why do I only get sound from the bottom poles?
Post edited by fanisius on
    tonyb Posts: 33,014
    One of two things come to mind.
    One- do you have both amps connected by a splitter from the receiver/preamp ? In other words, you have to split the signal comming out of the receiver, so one goes to each amp, for each set of poles.
    TWO- you toasted the tweeters.
  • fanisius
    fanisius Posts: 8
    Yes, I do. But problem persists, when I remove the Y and directly connect to amp going to the high-end directly to my main reciever pre-out.
  • nguyendot
    nguyendot Posts: 3,594
    So take the tweeters out of the enclosure and wire them directly to your receiver. Make sure the receiver is turned VERY LOW. If no sound comes out, the tweeter is toasted. IF sound comes out, your crossover is likely the culprit.
    Main Surround -
  • fanisius
    fanisius Posts: 8
    Speakers are only seven months old. Polk is a very durable brand. This would be disappointing @ $800 and very uncommon considering both speakers are affected.
  • cstmar01
    cstmar01 Posts: 4,424
    DSkip wrote: »
    You can blame Polk all you want, but if both tweeters are blown, it ain't their fault...
    bingo.
  • nguyendot
    It wouldn't be uncommon, likely if you fried the tweeter in one, it would fry the other because you clipped them or fed them some dirty signal.
    Main Surround -
  • fanisius
    fanisius Posts: 8
    I did this. The tweeters do not work. The crossovers do. I attached another high end speaker to the wires and there was sound. Did connecting the amps to the same pre-out, using a y-connector cause this to happen?
  • nguyendot
    Doubtful, more likely a faulty amp or you drove them to burning out.
    Main Surround -
  • fanisius
    fanisius Posts: 8
    I never drove them hard, but I think I blew them when I first hooked them up. I know I blew the fuses in the amp. My bad. quess I'll need to order replacements. Thanks for the help.
