Need help on fixing a hole
rromeo923
rromeo923 Posts: 1,513
edited November 2011 in Vintage Speakers
This is the top of one of my Monitor 10's
Any idea on quick fix. Not so concerned about looks.
Thanks!!
I got static in my head
Post edited by rromeo923 on
  • falconcry72
    falconcry72 Posts: 3,580
    anonymouse wrote: »
    is that a crack in the vinyl? or does it go all the way through the ndf?
    Looks like the vinyl is cracked and the MDF has been dented in, but not all the way through.
    If the MDF is not broken all the way through, then the only reason you'd want to fix it is for looks. If it is cracked all the way through, then your main concern is going to be sealing it. Check it out from the inside and see what's up. If the inside is fine, and you don't care about looks, then don't worry about it.:wink:
  • rromeo923
    Looked in the speaker (tons of polyfill) and there is a crack in the MDF. It is not a hole, however there is a crack. The speaker does not pass the push test. I have armacelled the passive and mids.
  • falconcry72
    rromeo923 wrote: »
    Time to seal the crack!:biggrin:
    I would suggest removing the drivers and passive, removing the polyfil, and putting the cabinet upside down. This give you room to work, as well as make sure that the MW's and passive don't get spilled on, plus whatever you use to seal the crack will seep right into it instead of away from it. Some wood glue might be all you need. Be generous and let it cure for a while before turning it back over. You could use some silicone caulk, or whatever is handy. I think a lot of different seals/fills would work adequately, so whatever you have handy is dandy.:biggrin:
  • falconcry72
    Before flipping it upside down, you could try pushing or tapping the depressed area from the inside to try and get the outside to be flush, just be careful not make it worse!
  • rromeo923
    Thanks!
  • skrol
    skrol Posts: 3,393
    Careful with silicone calks. Most can be corrosive to the speaker baskets, and other metals as they out-gas. I believe 3M Silicone II is ok. You might consider epoxy since you what something that dries rigid in this case. Depending on how much damage and how unstable it is, you may want to cut a thin piece of wood to fit over the area and glue it in place (on the inside) securely to prevent it from buzzing.
    Any idea how the damage occurred?
    Stan
    Stan
    Main 2ch:
    HT:
    Other stuff:
    F1nut Posts: 50,761
    I would.
  • gdb
    gdb Posts: 6,012
    Bondo to the outside...... done and done........maybe a little brown sharpie for looks.
  • rromeo923
    Bought speakers sight unseen. $60.00 Had hole in top to begin with.
    I was thinking Bondo.
  • inspiredsports
    inspiredsports Posts: 5,501
    Maybe Fix-A-Flat would work. Try the link in post #1 here . . .
    http://www.polkaudio.com/forums/showthread.php?126356-In-the-WTF-department
    Conrad Johnson PV-5 w/mods
    MF x-DAC V8, HAInfo NG27
    NAD SS rigs w/mods
    GIK panels
  • Phasewolf
    Phasewolf Posts: 514
    I would use Jb weld on the inside and if I was going to redo the vinyl on the outside I would pull the vinyl off Bondo it sand it and then apply new vinyl.
    Absolute corruption empowers absolutely.
    Lg 55LW5600 TV
    Onkyo PR-SC 5508
    Legacy Audio Focus SE
    Legacy Audio Silverscreen HD center
    Polk F/X500i Rears
    Parasound HCA-3500
    Sunfire Grand Cinema
    Behringer iNUKE NU6000DSP
    Pair of CraigSUB SS-18.1
    pitdogg2 Posts: 25,695
    why not try Durhams rock hard wood putty? mix it a little thin and let it seep into the hole from the inside....sand flat when dried...
