Final hook up question
Rocco1
Ok so I am about to start wiring and placing equipment in my new media room and was wondering how I should place my amps. I have a closet where most of my gear is going to be placed its about a 20 foot run from where the amps could go. Or should i run longer cables between the receiver and the amps and short speaker wire between the amp and speakers? Meaning i would put the amps right next to the speaker.
Equipment
2 Adcom 555se
bi-wired into
2 RTia9s
Equipment
2 Adcom 555se
bi-wired into
2 RTia9s
Man Cave: 7.1
-PS Audio Power Plant Premier
-PS Audio Power backup
-Onkyo Pre/Pro> 2 Adcom555se bridged and bi-wired> RTi A9s
> Adcom GFA 7605> CSi A6 center, RTi A3s side rears, FXi A6s rears
>Sub = MK Audio 10'
-PS3
-Onkyo 5 disc cd player
-Directv
-Samsung 59' plasma flanked by 2 Samsung 43' plasma's
>Sub = MK Audio 10'
-PS3
-Directv
Post edited by Rocco1 on
Shorter interconects. longer speaker wire. Best.
Hello,
The general consensus is that it's probably better to have short interconnects and longer speaker wires, than the reverse.
Regards, Ken -
That was what i thought just wanted to make sureMan Cave: 7.1
>Sub = MK Audio 10'
-PS3
-Directv
-Samsung 59' plasma flanked by 2 Samsung 43' plasma's -
Most certain shot IC runs. Also good air circulation around your equipment. Heat kills. Computer fans work well.
