Connecting a PSW505 to a Yamaha R-S500 Receiver
Automatox
The Yamaha R-S500 Receiver I just bought has a "Subwoofer Out" Port but the manual has very little information about this port (Amplified or not, Crossed over for only low frequency or not, etc...).
I am a newb when it comes to sub connections.
Should I just hook the Yamaha's Sub Out to the PSW505's LFE Port? If I do, what adjustments will I need to make on the Sub?
Note that this receiver has no "Small" or "Large" setting or any type of settings for the Subwoofer Out.
This is a 2 chanel receiver and I am running Monitor 70 II's as the Right and Left.
Thank you so much
Automatox
Thank you so much
Automatox
Post edited by Automatox on
Hello Automatox,
Welcome to Polk's forum. In all likelihood all you need to do is run a shielded RCA cable from the receiver's sub-out to the LFE input on the Polk. The only adjustment, on the sub, is the volume setting to blend with the Monitor 70s. Probably the 9:00 or 10:00 o'clock position would be a good place to start.
It's a bit unusual for the receiver not to have some kind of set up menu where the sub-out function is turned on/off. Maybe check with Yamaha to be sure.
Regards, Ken -
Thank you sir.
Automatox -
No problem, glad to be of help.
