Internal wiring SDA-CRS+
audiocr381ve
Hey fellas, I seem to have misplaced some of my internal wiring in my CRS+'s, mainly the wire from the crossover to the MW drivers. I was wondering if Canare 4S11 14-gauge cable would be acceptable to use.
Thanks dudes
Thanks dudes
Post edited by audiocr381ve on
audiocr381ve wrote: »Hey fellas, I seem to have misplaced some of my internal wiring in my CRS+'s, mainly the wire from the crossover to the MW drivers. I was wondering if Canare 4S11 14-gauge cable would be acceptable to use.
Thanks dudes
If it was me I'd try mil spec silver plated teflon coated stranded copper, avail on ebay or through surplus dealers. Cheap and many have had good results."Science is suppose to explain observations not dismiss them as impossible" - Norm on AA; 2.3TL's w/sonicaps/mills/jantzen inductors, Gimpod's boards, Lg Solen SDA inductors, RD-0198's, MW's dynamatted, Armaflex speaker gaskets, H-nuts, brass spikes, Cardas CCGR BP's, upgraded IC Cable, Black Hole Damping Sheet strips, interior of cabinets sealed with Loctite Power Grab, AI-1 interface with 1000VA A-L transformer -
That would work fine. Be sure to either use quick disconnects or tin the leads well before soldering them to the drivers."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
Got it, thanks guys.
Don't know. My results with silver plated copper have been... not good. I hear a nasty harshness/hash in every bit I've tried that isn't there when using either pure silver or pure copper.Turntable: Empire 208
Arm: Rega 300
Cart: Shelter 501 III
Phono Pre: dsachs consulting
Digital: Marantz SACD 30n
Pre: Conrad Johnson ET3 SE
