Basic question for sub input/output
crazyish1
crazyish1 Posts: 1
edited November 2011 in Electronics
Hello, I have a receiver with an LFE output (Pioneer VSX-1021-k). The receiver does not have a monitor output (a line level output that is active for all stereo inputs... I think). The polk subwoofer I have (PSW10) does not have an LFE input. Is there a cable that will allow me to take a LFE output and use it as the line level input into the sub?
If not what are my options?
Thanks.
Post edited by crazyish1 on
  • Glowrdr
    Glowrdr Posts: 1,103
    Not 100% sure, but I believe you can just use 1 of the inputs (but I've also seen some manuals that say to use a splitter to get more volume)
    So you should be able to just use a single RCA into a Y-splitter to the sub. This will still only get you the LFE sound though, but you should be able to get around that by changing some settings, or listening modes.
    (I just hooked up a new sub this afternoon, so I'm still playing with the settings myself)
    65" Sony X900 (XBR-65X900E)
    Pioneer Elite SC-37
    Polk Monitor 70's (2)
    Polk Monitor 40's (4)
    Polk Monitor CS2
    Polk DSW Pro 660wi
    Oppo BDP-93
    Squeezebox Duet
    Belkin PureAV PF60
    Dish Network "The Hoppa"
  • MADGSF
    MADGSF Posts: 603
    Glowrdr is right, you can just hook it to the left or right line level input. I do the same thing on my sub.
    AVR: Elite VSX-21TXH
    Amplifier: B&K 7250 Series ii
    Misc: Velodyne SMS-1
    Mains: RTi-10
    Center: CSi-5
    Rear: Boston DSi460
    Sub: SVS PC-Ultra
    TV: Panasonic TC-P58V10
    DVD: Panasonic DMP-BD60K
