amp---what to try next
sda2mike
sda2mike Posts: 3,131
edited November 2011 in The Clubhouse
i have an adcom gfa555...great amp...lotsa power...just thinking down the road i may want something of a different sonic variety..what would be a good amp to step to? i don't need more power..more storage maybe..budget under 600.
thanks
mike
Post edited by sda2mike on
  • dpowell
    dpowell Posts: 3,068
    You would want a tube amp. :biggrin:
    Parasounds tend to be a little more on the warm side and less bright than Adcoms. There's one option for you.
    polkaudio Fully Modded SDA SRS 1.2TLs + Dreadnaught, LSiM706c, 4 X Polk Surrounds + 4 X ATMOS, SVS PB13 Ultra X 2, Pass Labs X1, Marantz 7704, Bob Carver Crimson Beauty 350 Tube Mono Blocks, Carver Sunfire Signature Cinema Grande 400x5, ADCOM GFA 7807, Panasonic UB420, Moon 380D DAC, EPSON Pro Cinema 6050
  • sda2mike
    i like that.....would go good with the tube pre;)
    Toolfan66 Posts: 17,361
    Pass labs x350
    Kidding of course!!!
  • BlueFox
    BlueFox Posts: 15,251
    sda2mike wrote: »
    What is amp storage?
  • sda2mike
    BlueFox wrote: »
    filter caps..capacitance, i thinks..i'm sure you know the rest;)
  • sda2mike
    beasts are beautific!
    the pass amp, that is
  • dpowell
    A tube amp provides lighting so you can see what's in the storage units.
  • rromeo923
    rromeo923 Posts: 1,513
    Tubes!
    I got static in my head
  • sda2mike
  • Drenis
    Drenis Posts: 2,871
    I thought "storage" meant headroom. :p
  • sda2mike
    you thought correctly, i guess...storage refers to the capacitance (sp?) value....for my adcom..the 4 big caps total 60,000..a big # like that and higher will give greater headroom...
    heiney9 Posts: 25,221
    sda2mike wrote: »
    Not necessarily, just like "bigger" horsepower doesn't always mean a faster car. It's all in how the output stage is designed. As a general blanket statement you could say that, but it's not really something that a buying decision should be made on.
    My amp which is 30wpc has 120,000uF of capacitance in the form of (6) 10,000uF caps per channel. Whose amp has more headroom? Who knows, who cares really.
    My point is don't look at a singular aspect of design and automatically assume it;s the same for every design. You certainly don't want wimpy capacitance for your power supply if it's a big amp, etc. But you have to look at the entire package and see if all the parts "add up".
  • falconcry72
    falconcry72 Posts: 3,580
    sda2mike wrote: »
    Capitance is cool... don't forget current, too...
    Parasound HCA-2200mkii:
    - Two independent 1200vA toroid power transformers
    - 100,000uF computer-grade capacitors in power supply
    - Current Capacity
    50 amperes continuous
    90 amperes peak
    http://www.parasound.com/vintage/hca2200.php
    You might be able to find one for 600, def. 700. The trick is finding one for sale.
  • Drenis
    Drenis Posts: 2,871
    sda2mike wrote: »
    Just like h9 said in his post, bigger isn't always better. My Carver TFM-42 was modded with a custom PCB housing multiple small caps instead of the 2 larger caps the originally came in the amp. The power is endless... I honestly couldn't imagine more?
