Sonicraft inductors for 2B
gmcman
When I get to the X-over TL-upgrade, I plan on using the custom boards from gimpod and was thinking on using new inductors, for no other reason to leave the stock ones attached, and the possibility of newer ones being as good or better than the stockers.
Has anyone used the Sonicraft inductors and if so what were the findings?
Re-use the originals. The inductors Sonic Craft carries wouldn't be a good match due to differences in DCR."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
