RT3000p T/S Parameters.
VR3
VR3 Posts: 29,720
edited November 2011 in DIY, Mods & Tweaks
The woofer weighs to much for the scale to get the rest of the data so this will have to do for you hooligans!
If this is a No-No, please delete!
WT3.jpg 285.3K
  • dorokusai
    dorokusai Posts: 25,642
    If you have the speaker and the software to do it, I'm not sure why it would be wrong and honestly I think it's helpful.
    VR3 Posts: 29,720
    Just making sure! :-D
  • halo71
    halo71 Posts: 4,642
    Got that information for the Lsi15 by chance?
    --Gary--
    VR3 Posts: 29,720
    No....sorry
  • Face
    Face Posts: 14,340
    halo71 wrote: »
    I've measured LSi15's, but never saved the data for some reason...probably because I never intended to publicly post it. IIRC, they only dip down to 3ohms briefly and are easier to drive than LSi9's.
    VR3 Posts: 29,720
    I should have specified, this is the driver from the subwoofer enclosure on the RT3000p - not the entire speaker... :)
  • halo71
    halo71 Posts: 4,642
    Face wrote: »
    Can you tell me how much real estate the subwoofer occupies? Inside cabinet volume for the stock sub? I looked at the specs for the "upgrade" sub for the 15's. And it's recommended cabinet size seems to be much smaller than the Lsi15 cabinet.
    --Gary--
  • Face
    Face Posts: 14,340
    I no longer have a pair of LSi15's here.
    The woofer section of the LSi15 does appear pretty small inside though.
  • halo71
    halo71 Posts: 4,642
    Like this small?
    Vas .42 cubic feet/11.9 L
    --Gary--
  • Face
    Face Posts: 14,340
    Or maybe a little larger. Just because those are the recommended specs, doesn't mean the woofers wouldn't work in a different size cabinet with different tuning.
    Where are you getting your specs from, their automotive enclosure recommendations? If so, that's a little different than the home environment.
  • dorokusai
    He's convinced that there's no reason the upgraded db subwoofer should work in the LSi15 enclosure....although everyone who's done it noticed an improvement and is happy.
  • halo71
    halo71 Posts: 4,642
    Face, I got it from a polk site. Yes I think it is in fact specs for a car enclosure.
    Mark, you are way off base with that comment. Not sure what your deal there is. I am not one of the folks around here that does not listen when people talk! I simply asked that question, to you first and now here. Because I BOUGHT 2 original LSi15 woofers and have plans to use them in a DIY project.
    --Gary--
    VR3 Posts: 29,720
    Hey Gary
    If you are going to be into DIY like it seems, I would recommend picking up the WT3 kit from Parts Express. It is bad ****...
  • halo71
    halo71 Posts: 4,642
    Thanks Trey!
    --Gary--
  • Face
    Face Posts: 14,340
    Gary, no offense, but I can see where Mark was coming from.
    Pick up a Woofer Tester(can also measure caps and coils) and download the woofer box program here: http://audio.claub.net/software/jbabgy/jbagby.html You can easily play around with different cabinet sizes, tuning, alignments, and it gives some great info that WinISD doesn't show.
  • dorokusai
    halo71 wrote: »
    I have no deal or vested interest in any of it so not sure why you're so weirded out.
    You mentioned this in a PM, in regards to the cabinet volume of the LSi15 vs the upgraded DB woofer....what's being lost in translation here aside from a cut and paste of your actual message? I don't know the actual cabinet Q or Vas but offered the fact it's a larger cavity than it may appear of which may or may not even be useful. I don't build speakers.
    Your question is legitimate and I stated that it was a direct recommendation from Polk Engineering, regardless of the actual numbers being spot-on. I tend to not second guess, for the most part, the folks that actually built what we're talking about.
  • halo71
    halo71 Posts: 4,642
    Ok, I am gonna say this one last time. It's not worth the argument. The specs on the new upgraded woofer are Vas .42 cubic feet/11.9 L. Now, just looking at pics of an LSi15, it's cabinet size seems a bit bigger. Do you not agree? THAT is why I asked the question I asked. It is not because I think the Polk engineers are full of $hit. It was assumed that I did not believe them when I never said anything to the contrary. I asked a simple question, thats it! I am not experienced speaker builder either, hence the question!
    I know now not to ask direct DIY questions I guess.
    --Gary--
    VR3 Posts: 29,720
    You can put that woofer in whatever box you want as long as the tuning you desire is achieved... if you are using a port it is important to achieve low port turbulance while still allowing the port to load and be effective
  • halo71
    halo71 Posts: 4,642
    Thanks Trey!
    --Gary--
