Denon mc103 with pio pl100 turntable
EDUBAG
EDUBAG Posts: 403
edited November 2011 in 2 Channel Audio
Hey guys,
just like the title says, do any of you know if the denon cartridge goes well with the pioneer pl100 turntable? Currently i am using the shure m97xe with good results, but would like to do the next step and do not know if that step should be a better turntable or a better cartridge.
I think to go with a better cartridge would be more beneficial but this is why i am asking the more knowledgeable group here at the forum.
Regards,
eduardo
HT:
POLK AUDIO RTI4 FRONTS
CSI3 CENTER
DEF TECH PROMONITOR800 SURROUNDS
PSW 125 SUB
PIONEER ELITE AVR23TXH AVR
APPLE TV 160GB
PANASONIC BLURAY PLAYER
50" PANASONIC PLASMA TCP50C2
2 CHANNEL:
KEF R300 THREE WAY BOOKSHELF GLOSS PIANO BLACK
ROTEL RC 990BX PRE
ROTEL RB 990BX AMP
OPPO DV980 (AS CD PLAYER)
PIONEER PL100 TURNTABLE WITH SHURE MX97E CART
MIT EXP2 SPEAKER CABLES
Post edited by EDUBAG on
  • EDUBAG
    EDUBAG Posts: 403
    keiko wrote: »
    the dl103 is a low output moving coil. Depending on your phono stage, you may need a step up transformer. I checked the compliance and you're ok there. Another alternative, and less expensive would be the dl110. This is a high output mc cartridge, similar to the dl160, excellent bang for your buck cart. For the $.
    The pl100 is a decent entry level table. It was my first real turntable as a matter of fact, but i wouldn't invest a lot on a cartridge for it. Imo, you'd be better served with the dl110. No need for a step up since it will work in both mm/mc phono stages. Hope this helps.
    http://www.needledoctor.com/denon-dl-110-cartridge
    http://www.needledoctor.com/denon-dl103
    http://www.vinylengine.com/library/pioneer/pl-100.shtml
    i will be using the phono section on my rotel rc990bx which can handle mc/mm cartridge, but i do not know about low output vs high output mc. What do you think?
    HT:
    CSI3 CENTER
    PSW 125 SUB
    APPLE TV 160GB
    2 CHANNEL:
    ROTEL RC 990BX PRE
    ROTEL RB 990BX AMP
  • steveinaz
    steveinaz Posts: 19,545
    Aren't H.O. MC cartridges generally connected to the MM input?
  • thsmith
    thsmith Posts: 6,082
    steveinaz wrote: »
    yes....
