Time for an upgrade
dskns26
dskns26 Posts: 8
edited November 2011 in Electronics
I currently have a Harman Kardon AVR 235 and I am looking to upgrade to something more up to date. I like the HK but I am open to other brands as well. I am looking for 7.1 and I use it for about 75% movies/tv and 25% music. My fronts are Polk Monitor 60's, center CS10, surrounds are old HTIB Sony satellites that I am also looking to upgrade and a BIC PL-200 sub. My living room is 30x14 but is open to other rooms. Any suggestions or thoughts would be greatly appreciated.......Thanks!
Post edited by dskns26 on
  • drummer86
    drummer86 Posts: 441
    Welcome to CP!
    If you want to stay with HK check out their ebay store. You can get great prices on refurbed AVR 254/354s with factory warranties. Your price range would help to give more specific advice. Happy hunting!
    Display: LG 47" LCD | AVR: Marantz SR5005 | BD: Panasonic BDT-210 | CD/SACD: Oppo 980 |
    Amps: Rotel RB-990bx | Marantz MA-500 | Speakers: Totem Mite : Totem Mite-C : RC60i | Sub: HSU VTF-2 MKIV
    HK AVR635 | Polk R30 | Sony DVD/SACD Player
  • Phasewolf
    Phasewolf Posts: 514
    What are you looking to spend? Newegg has the Pioneer VSX-1021-K for $300 use promo code EMCJJJJ24
    It is a nice unit and has gotten good reviews so far.
    Absolute corruption empowers absolutely.
    Lg 55LW5600 TV
    Onkyo PR-SC 5508
    Legacy Audio Focus SE
    Legacy Audio Silverscreen HD center
    Polk F/X500i Rears
    Parasound HCA-3500
    Sunfire Grand Cinema
    Behringer iNUKE NU6000DSP
    Pair of CraigSUB SS-18.1
  • drummer86
    Here's HomeTheater's review of the 1021. Take it for what it's worth but many seem to find the power lacking a bit.
    http://www.hometheater.com/content/pioneer-vsx-1021-av-receiver
    HT Labs Measures
    Five channels driven continuously into 8-ohm loads:
    0.1% distortion at 46.1 watts
    1% distortion at 56.7 watts
    Seven channels driven continuously into 8-ohm loads:
    0.1% distortion at 44.5 watts
    1% distortion at 53.7 watts
  • Phasewolf
    That is odd the one I seen listed on newegg has different specs. It was listed at 110work watts per channel the one they reviewed was not the 1121-k are they the same?
    Lg 55LW5600 TV
    Onkyo PR-SC 5508
    Polk F/X500i Rears
    Parasound HCA-3500
  • Phasewolf
    Can't edit with my phone I wanted to say 1021-k
    Lg 55LW5600 TV
    Onkyo PR-SC 5508
    Polk F/X500i Rears
    Parasound HCA-3500
  • drummer86
    That's the approximate rating for running two channels. As you can see it drops considerably when you spread that out over 5 or 7. All depends on how the company rates their amps.
    txcoastal1 Posts: 13,499
    The 1021 will work great had the 1020 for my HT powering my LSi equipment for a week while waiting on my SC-35 and Sunfire
  • nguyendot
    nguyendot Posts: 3,594
    Phasewolf wrote: »
    "Advertised Specs" and "actual output" are two totally different things my friend. A receiver that actually puts out 110 watts per channel all channels driven would A) cost $3000 not $300, and B) weigh about 60lbs+.
    Main Surround -
  • Erik Tracy
    Erik Tracy Posts: 4,673
    How much money do you want to spend?
    Do you mind buying used, or does it have to be new?
  • dskns26
    dskns26 Posts: 8
    I am looking to spend $700 at the most. I have never thought of getting used but if it were to come with a warranty I would be open to that. Any thoughts on Denon avr-1912? As for the Pioneer, I wasnt sure if I needed to look at the Elite line as opposed to the regular line?
    tonyb Posts: 33,066
    What ever you do, get a receiver with pre outs otherwise you limit yourself to what speakers you can upgrade to in the future. Speaking of speakers, the ones you have now seem a tad on the light side given those room dimensions and open areas.
  • jbooker82
    jbooker82 Posts: 1,627
    $700 bucks will get you a used (referbished) Onkyo TX-NR809 with a 5 year warrenty. 135 watts per channel. 7.2 analog outputs, Audyssey MulitEq XT automatic setup, 4k upscaling, powered 2nd zone, 192/24 bit Burr-Brown DAC
    http://www.accessories4less.com/make-a-store/item/ONKTXNR809/Onkyo-TX-NR809-7.2-Channel-Network-A/V-Receiver/1.html#!more
    AVR: Onkyo Tx-NR808
    Rear: FXI A4
    Sub: Polk DSW Pro 660wi
    TV: LG Infinia 50PX950 3D
    IC: AudioQuest Black Mamba II
  • dskns26
    dskns26 Posts: 8
    Thanks for all the input. I have been thinking the same thing about upgrading the fronts and center due to room size but budget becomes a concern for me. I can save a little on an AVR and get the onkyo tx-nr 609 for $380 from Newegg and put savings towards new speakers. Any thoughts on the 609?
