No Sound is coming from my 3000 sound bar
Newbie75
Newbie75 Posts: 1
edited November 2011 in Forum Testing Area
Hi there I have never posted in any forum before and I am not great with figuring out stuff like this so any information would be greatly appreciated. So, I hooked up my 3000 stereo bar and linked it to my Mitsubishi remote and the volume worked just fine. An hour later I turned everything back on and there is no sound. I doubled checked all of the connections and everything is where it should be. I can hear that the bar is on but I can't figure out why it is not working. I have tried to reprogram my remote 3 times, all of the lights blink like the manual states but it still doesn't produce any sound. I have tried to use to Polk audio remote and tried using the volume button on the bar itself. HELP please!
Post edited by Newbie75 on
  • [Deleted User]
    [Deleted User] Posts: 7,598
    Hello Newbie75,
    Thanks for posting on Polk's forum, I'm sorry you're having a problem. You would want to be sure your TV's setup menu has the audio set for PCM output as opposed to Dolby digital. This should be covered in the TV's owner's manual. If you are still having problems telephone Polk's CS at 1-800-377-7655 or email to polkcs@polkaudio.com.
    Regards, Ken
