Need Fast Answer on Surrounds
I have second thoughts on what I ordered, might be too late too change but a fast answer is what I need.
I ordered LSI front stage with Fxi A4's for surrounds and rear, I have second thoughts on the rear.
Should I get one pair of LSIFX for surrounds and the FXI A4 pair for rear surrounds? Or just stick with all FXI A4' surrounds and rear?
If I got the lsifx surrounds Id just need a 5 channel amp instead of a 3...
Yamaha A2000/Emotiva Xpa5/Oppo 93/Polk Lsi15/Polk LsiC/Polk FxiA4 Surround/Polk FxiA4 Presence/Mtx Powered Sub
Post edited by burts on
The FXI's will work, but if you can fit the LSiFX's, I'd go that route. (I could not due to size/placement) You should be safe to run them off of your AVR if your amping your frontstage.
