adcom GFA-555II common grounded? SDA2a - pin/blade IC cable = Where????
jaygax
i just won an adcom GFA-555II amp on ebay. is this a common ground amp for my SDA2a?
where the heck am i gonna find a pin/blade interconnect cable for my SDA speakers? would polk make one to order? or anybody here know how to make one? can i be able to make my own interconnect cable? please help.
:rolleyes:
:rolleyes:
Post edited by jaygax on
Yes, it is common ground.
There are people that do make pin/blade cable. There are also instructions on the site here on making your own. It is pretty simple as you just need to connect the two pins. You can do simple solutions like just take a single speaker cable and jam the bare wire in each pin hole. You can use RCA connectors in the pin hole with the ground removed. Some people put a five way binding post in place of the pin hole and use a regular speaker wire connection. -
I have an extra pin/blade IC. PM me if you want it... I use an after market one which I would suggest if you can get one.
check your inbox. i sent you a PM together with my mailing adress. thanks.
