Speaker stands, recommendation needed
Hey guys i am looking for a good affordable pair of speaker stands between 24 and 26 inches tall and with cable management and fillable. I plan on using with rti4 but will be upgrading in december to either the lsim703 or kef r300.
I usually have towers therefore i do not know much about stands.
Any recommendation is welcome
Regards,
Eduardo
Regards,
Eduardo
HT:
POLK AUDIO RTI4 FRONTS
CSI3 CENTER
DEF TECH PROMONITOR800 SURROUNDS
PSW 125 SUB
PIONEER ELITE AVR23TXH AVR
APPLE TV 160GB
PANASONIC BLURAY PLAYER
50" PANASONIC PLASMA TCP50C2
2 CHANNEL:
KEF R300 THREE WAY BOOKSHELF GLOSS PIANO BLACK
ROTEL RC 990BX PRE
ROTEL RB 990BX AMP
OPPO DV980 (AS CD PLAYER)
PIONEER PL100 TURNTABLE WITH SHURE MX97E CART
MIT EXP2 SPEAKER CABLES
CSI3 CENTER
PSW 125 SUB
APPLE TV 160GB
2 CHANNEL:
ROTEL RC 990BX PRE
ROTEL RB 990BX AMP
Post edited by EDUBAG on
Try these http://www.audioadvisor.com/prodinfo.asp?number=PGDS03. I'm using them with my 703s with great results.
Thank you which hight are you using?HT:
CSI3 CENTER
PSW 125 SUB
APPLE TV 160GB
2 CHANNEL:
ROTEL RC 990BX PRE
ROTEL RB 990BX AMP
MIT EXP2 SPEAKER CABLES -
I'm using the 28" on my LSi9's. I think that height/weight combo is about the most for that stand. Good build quality, but if I we're to do it again I might find something with a bit more beef. They'll work great for something a bit smaller than the 9's, good luck.
Oh, if you search Pangea on the forum, I've got a thread about them somewhere. -
I'm using the 28" stands also. They do quite fine with the 703s and seem to be very stable, especially after loading the front tubes with sand.
