Upgrading Speakers Changing Existing Speaker Placement
burts
burts Posts: 33
edited November 2011 in Speakers
Im upgrading to polk lsi 15, lsic, fxi4 surrounds(2 pairs) This is where my existing surround and rear surrounds are placed. My main seat is the recliner on the right directly in front of my tv.
This is my Rear Surrounds, Side surrounds
Should I put my rear surrounds right behind my seat instead of the corners, back wall behind my seat is less then 2 feet away
Should I put my side surrounds closer to my couch on the side walls, seen in 3rd picture on the right side of the doorway instead of the left?
Yamaha A2000/Emotiva Xpa5/Oppo 93/Polk Lsi15/Polk LsiC/Polk FxiA4 Surround/Polk FxiA4 Presence/Mtx Powered Sub
Post edited by burts on
  • 20hz
    20hz Posts: 636
    I think the far cornors are the best , if you go low and behind the couch you will have a hard time balancing them , they will always sound closer and you will loose the depth of surround .
