Upgrading from a PSW 505 Experinces?
tommyt21
tommyt21 Posts: 685
edited December 2011 in Speakers
Hey guys
I need help in choosing to upgrade my weakest link. My PSW 505. It is a great sub for the coin I paid however I need something that drops low and clean. looking to spend below $600 Im 80/20 HT. Would really like to hear stories of those who owned the 505 then moved up.:twisted:
Living Room
Fronts: RTi A7's
Center: Csi A6 VR3 "Fortress Plus"
Front Heights: Rti A1
Surrounds: Rti A3
Sub: HSU VTF-2 MK4 Damn this is a good SUB
Pioneer Pioneer Elite: SC-35-> Emotiva XPA-3
TV: Lg LW6500 55" Passive 3D
Blu-Ray Panasonic BD 210
XboX 360 Slim/Kinect
Acoustimac red suede panels
Post edited by tommyt21 on
  • Erik Tracy
    Erik Tracy Posts: 4,673
    edited November 2011
    Well, my story doesn't exactly qualify, but...started with a PSW303, then went the upgrade route to an Epik Valor sealed sub and I'm 80-music/20-HT....still have the Valor (about $600 but no longer available).
  • B Run
    B Run Posts: 1,888
    I went from a 505, to dual 505's to an SVS 16-46 to an SVS pb12 and am really happy with were i'm at. The 505's just can't come close to the SVS's, it's a night and day difference. I bought mine used less than 6months old for $475, so shop around and you'll be able to get a hell of a sub for $600. Check out SVS, Epik, HSU and ED. Good luck!
  • rooftop59
    rooftop59 Posts: 8,121
    I have never owned a psw505, but I did own a cadence x-sub12, which is very similar (it hit 104 db at 25hz in my room which is about what the psw505 can do according to ed mullen of svs's review). I now have an HSU vtf-3r which is basically an older version of the vtf-2 mk3, and it is night and day. Deeper, tighter, cleaner, the frequency response is very flat, and very authoritative. I will say that in my dual rig, the main objective is always music, and from what I have read the SVS's will get you a little more output at a little lower hz, but at the expense of musicality (however, I have never actually heard one). So there is my 2 cents for what its worth...
    Game Room 5.1.4:
    Bedroom 2.1
  • tommyt21
    tommyt21 Posts: 685
    I was eyeing the HSU vtf-2, however anything i pick needs to be light years ahead of my psw 505 since i just dropped 5k on new stuff and wont be able to upgrade for a while after changing subs WAF you guys understand lol
    what about outlaw and lava how do they compare?
    Living Room
    Fronts: RTi A7's
    Surrounds: Rti A3
  • rooftop59
    Dude an hsu vtf2 mk3 is light years ahead of what you have. But I am sure others will chime in.
    Game Room 5.1.4:
    Bedroom 2.1
  • danz1906
    danz1906 Posts: 5,144
    Linn AV5140 fronts
    Linn AV5120 Center
    Linn AV5140 Rears
    M&K MX-70 Sub for Music
    Odyssey Mono-Blocs
    SVS Ultra-13 Gloss Black:D
  • falconcry72
    falconcry72 Posts: 3,580
    rooftop59 wrote: »
    I wouldn't call it light years ahead. For the budget he's got, he could easily get a vtf-3 instead of a vtf-2, which is a HUGE difference. The vtf-3 is light years ahead. The new vtf-3 mk4 is 699 new from HSU. He should be able to find the vtf-3 mk3 used for 400-500.
  • tommyt21
    tommyt21 Posts: 685
    How is the ed a5-300 compared to the 505
    Living Room
    Fronts: RTi A7's
    Surrounds: Rti A3
    EndersShadow Posts: 17,596
    tommyt21 wrote: »
    No comparison from what I have heard. Ed A5-300 trounces it
  • tommyt21
    tommyt21 Posts: 685
    The more and more I read I think the HSU vtf-2 mk4 is what I will get to replace my psw505, Unless anyone has a really good reason why i should get something diffrent. My room size is under 2200ft3
    PS any issues with a down firing sub? Currently mine is in a corner behind one of our couches so i get alot of boomy reflections.
    Living Room
    Fronts: RTi A7's
    Surrounds: Rti A3
  • rooftop59
    Mine vtf-3r is setup as an end table next to the couch and is down-firing onto faux hardwood floors. It sounds great even being about 12 feet from my monitors. Flat response, not boomy at all. YMMV.
    Game Room 5.1.4:
    Bedroom 2.1
  • MrGlobe
    MrGlobe Posts: 401
    Is DIY an option? You could put together quite a monster sub for that amount of money
  • tommyt21
    tommyt21 Posts: 685
    I could do DIY. I just dont have the time Kids, wife, work, school..ect
    Living Room
    Fronts: RTi A7's
    Surrounds: Rti A3
  • tommyt21
    tommyt21 Posts: 685
    Between the HSU VTF-2 MK4 and the OUTLAW LFM-1 EX @ the esame price which is the better pick?
    Living Room
    Fronts: RTi A7's
    Surrounds: Rti A3
  • rooftop59
    Well I really doubt that anyone has actually heard both (especially since the former is new), and one is Dr. HSU's own company and the another was designed with his help, so I doubt there is much difference other than aesthetic. I personally think the standard finish on the outlaw looks a little nicer than the standard finish on the HSU, but that's just me. I personally would go with the HSU because it has a sealed option which might be ideal for music, but if music is not that important to you then its pretty much a toss up. Sorry for the lack of help...
    Game Room 5.1.4:
    Bedroom 2.1
  • nguyendot
    nguyendot Posts: 3,594
    Paradigm Sub2.... nomnom
    Main Surround -
  • tommyt21
    tommyt21 Posts: 685
    How would going from the psw505 to a ed a2-300 be?
    Living Room
    Fronts: RTi A7's
    Surrounds: Rti A3
  • rooftop59
    the ed would definitely dig deeper and hit harder, but it wouldn't be as obvious an upgrade as the HSU. I owned the ed A3-300 and while it was great for HT, and a big improvement in terms of deep bass extension over what I had at the time, it was a little slow on music. the kick drum lingered for a little too long, which really bothers me. I don't notice that with the HSU, and it hits as hard and digs as deep, and the new one has a sealed option which should be incredible for music.
    Game Room 5.1.4:
    Bedroom 2.1
  • tommyt21
    tommyt21 Posts: 685
    Outlaw and I had some issues with shipping so my order was canceled and I pulled the trigger on HSU's newly improved VTF-2 MK4.
    After it comes in I'll post a review comparing the two just in case others had similar upgrade questions on the PSW505.
    ps anyone own this sub already?
    Living Room
    Fronts: RTi A7's
    Surrounds: Rti A3
