Whats a good Gas Line?
Unknown
edited November 2011 in The Clubhouse
These are good gas lines, probably the best gas lines you have ever heard.:cheesygrin:
These are prototypes I made to try a new wire out.
Made with chainsaw/lawmower gas line (I always use that, and believe it or not, it is killer.......high temp teflon content?), the wire is uninsulated 6N OCC silver plated (The silver is also 6N:cheesygrin:) copper solid core.
Nakamichi LOCKING rca plugs.
THESE ARE SHORT UNSHIELDED IC'S (as not to waste wire).
Roughly 20" tip to tip.
Everything is brand new never used, although these have been in my system for some time, so should already be burned in, or close to it.
I make these because they are quick and easy.
I have made these with every new wire I have bought (brgman has a couple of pairs of "prototypes" of mine).
I don't buy cheap wire and the fact that they have been in my system for a while should tell you something.
Pick a number between 1 and 125 (the number has already been picked).
I will draw next Thursday (11-10).
I am going to include Canada and the lower 48 states ONLY (Larry777 made it easy, so there is no problem shipping to Cananda).
I will not ship anywhere else.
PLEASE DO NOT PICK THE SAME NUMBER TWICE!
Here is a pic of the actual cables you will receive (I pay shipping).
Attachment not found.
