Speaker Wire Under Carpet.
camp21178
camp21178 Posts: 273
I was just wondering if anybody here has run wire underneath carpet. I'm getting new carpeting in my family room and I'm not happy with the wiring I just ran behind my baseboards. My room is 4 feet below grade and I ran the wire to my rear speakers behind corner trim up to a ledge that is 4 feet high. Any thoughts would be appreciated, thanks!
  • chumlie
    chumlie Posts: 8,658
    edited November 2011
    Tell the installer to leave padding about a half inch away from wall, then drop your wire in before the carpet gets kicked in. then have him notch corners to bring it up the wall. As long as your not stepping on it and have decent insulation on wire you should be fine. It worked for me.
  • camp21178
    Thanks, that sounds like a good idea.
  • leftwinger57
    leftwinger57 Posts: 2,917
    also you run an electrical snake after the fact and use the tackstrip as a guide.Just pick up very little on the corners to expose the snake. However I do not think is recommended for very low gu. thick spkr wire. If any concerns about fire there are none w/ spkr wire runs.
  • burts
    burts Posts: 33
    For my pc 5.1 i got the wire right under my carpet, i run it over everday with my chair for the last 7 years still going HeHe
    Yamaha A2000/Emotiva Xpa5/Oppo 93/Polk Lsi15/Polk LsiC/Polk FxiA4 Surround/Polk FxiA4 Presence/Mtx Powered Sub
  • slush
    slush Posts: 124
    I'm getting ready to have to do the same thing. My new house is a two story home and I can't pull wires in the attic like I did at my last home.
    I may end up pulling around the crown molding and then down, limiting where I have to pull under the carpet.
    EndersShadow Posts: 17,762
    if possible, think about dropping it through the walls/ceiling and use wall plates then connect your surrounds to those. I know SilverTuner did that in his townhome and it looked quite nice.
  • olddog
    olddog Posts: 10
    Back under the moulding and your fine if you have to cross the tack strip be certain to cut a notch of it out so the tacks don't penatrate the wire.
