transformers
defpotec
defpotec Posts: 5
hi,
I've just bought a psw505 from the U.S. and I'm trying to set it up in Hong Kong. does anyone know the in's and out's of transformers that will keep the sub going on a power supply of 220V 50hz here in Hong Kong? is it as simple as getting a step up transformer larger than the max rating of the sub or is it more complicated than that?
i'm running the 505 through a Denon 1912. has anyone heard of swapping out power supplies in the sub itself? or maybe it's as easy as a switch inside the box somewhere?
any help would be great!
thanks,
Dave
Post edited by defpotec on
  • [Deleted User]
    [Deleted User] Posts: 7,658
    edited November 2011
    Hello Dave,
    Welcome to Polk's forum. You'll need a "step down" transformer that will convert 220VAC to 110VAC, the operating frequency isn't a problem. Are there other components that you have the same issue with? Or, just the sub?
    Regards, Ken
  • defpotec
    defpotec Posts: 5
    Thanks!
    No, the receiver is from hong kong as are the other speakers. How large of a transformer do I need? The sub is 300W contiinuous and 460w max. Will a 500w transformer be enough? I heard I should get 40-50% larger than max rated power.
    Thanks again!
  • [Deleted User]
    It would be best to check with Polk's CS at 1-800-377-7655 or send an email to kjasper@polkaudio.com. He'll know the current rating of sub's bass amp protection fuse and help you determine the power demand of the sub. The Forum's own member, "NAP" was the go-to-guy for all things relating to sub amps.
    How's the food in Hong Kong?
    Cheers, Ken
  • defpotec
    defpotec Posts: 5
    I've sent them an email yesterday and waiting for a reply. Do they usually respond quickly?
    Food is not bad here although I do miss the grub in the states.
  • [Deleted User]
    It might be a good idea to send a copy of your email to the address I gave above, that's the CS manager.
  • inspiredsports
    inspiredsports Posts: 5,502
    post 7 carl6lke reported as spam for removal
    Conrad Johnson PV-5 w/mods
    MF x-DAC V8, HAInfo NG27
    NAD SS rigs w/mods
    GIK panels
  • defpotec
    defpotec Posts: 5
    Well I guess I'm going to go out and get a 500 watt transformer. Polk tech support says it should work but they're unsure about the frequency change from 50 to 60 hz.
    Has anyone actually run a sub through a transformer?
  • [Deleted User]
    The operating frequency won't make a difference, the sub's power supply converts the incoming AC to DC. I imagine a power supply that used a "pi" type filter, tuned to 60Hz, could be slightly effected, but that's not a problem here. You should be fine, lots of people do exactly what you're doing with no problem.
  • defpotec
    defpotec Posts: 5
    That's good to hear! Tried to set it all up today and the problem I'm having now is that when I plugged the 500 watt transformer in the wall and turned it on (with nothing else plugged to it yet) it turned on for a second and then shut down! Their is a 5 amp fuse in the box that I think blew but I don't know why. I hope I can get this sorted out!!
  • [Deleted User]
    That is quite unusual, I would contact the store where you bought it before plugging it in again.
  • Sherardp
    Sherardp Posts: 8,038
    You should be fine. I would check the breaker the transformer is plugged into. I'm in Japan and use a step up transformer since they use 100v 60HZ. I have not had any issues with my gear and I have been using it this way for about 5-6 yrs or so. All my gear is from the USA including power amps, and receiver. You should be fine.
  • Bobby11
    Bobby11 Posts: 1
    edited December 2011
    defpotec wrote: »
    Hi there,
    I'm about to have the same problem as you (using 220V 50Hz, then step down to 110V 50Hz).
    Not sure how things sort out? I would like to know.
    Thanks,
    Bob
  • Sherardp
    Bobby11 wrote: »
    Hi there,
    Thanks,
    Bob
    What is your concern or question?
