Bypass Capacitor
mlhm5
mlhm5 Posts: 217
edited November 2011 in Vintage Speakers
anyone use a bypass capacitor like the Vishay MKP1837 on the tweeter cap? Any reason why this would work better than not using it?
Post edited by mlhm5 on
    heiney9 Posts: 25,497
    You don't need a bypass cap if your main cap is up to the task. Use Clarity or Sonicaps and there is no need to bypass. Some people believe you can take a mediocre cap or even a lowly electrolytic cap and bypass with a small value cap like the Vishay or other better cap and make it sound a little better. Why not just use a musical cap in the first place? To me it;s just a band-aid or a cheap way out.
    VR3 Posts: 29,549
    I use bypass caps because of size constraints most of the time ;)
    But then again Im trying to shove 2 gallons of stuff in a 1 gallon bucket most of the time too ;)
  • Face
    Face Posts: 14,340
    Bypass caps in the tweeter or mid circuits have a negative effect on imaging. Buy a quality cap and there's nothing else to worry about.
  • dorokusai
    dorokusai Posts: 25,576
    Face wrote: »
    Absolutely. It's usually a fix for something that sucks in the first place or to make up for a shortcoming on the cheap. Buy the correct part, the right part and a quality part....this will never even cross your mind afterwards.
