Wiring speakers to a sub-woofer (?)
Rataxes
Rataxes Posts: 5
Hi
I have PSW 125 sub wired to a 5.1 receiver . I have noticed that there is a speakers out in the bottom of the sub.
Can I use this option to wire two more speakers as same as in the receiver ?
Thank you for your help
Post edited by Rataxes on
    F1nut Posts: 52,164
    edited October 2011
    ~No~
  • Gavin.Wright
    Gavin.Wright Posts: 125
    edited October 2011
    those speaker outputs are only functional if you are using the speaker level inputs on the sub... if you are running a line level signal to the sub the speaker inputs/outputs will not be functional. you cannot add additional speakers by connecting to them and they are not intended for such use.
  • Rataxes
    Rataxes Posts: 5
    edited October 2011
