SRS 3.1tl pin/blade socket
bluecomet
bluecomet Posts: 1,118
edited October 2011 in Vintage Speakers
Could someone explain to me how I can replace the pin/blade socket on the back of the speaker. A pin from an interconnect cable snapped and is stuck in pin hole. Is a small allan wrench needed. I see two small holes. One on each side of the pin/blade socket. The back side of it is hot glued which is not a problem. Any help would be appreciated.
Polk HT system 1: LSIC, LSI25 mains, LSI F/X rears, Lsi F/X rear centers,
Yamaha RX-V2500 System, Carver A753 3 channel amp.
Polk HT system 2: , SRT system with f/x 1,000's rear speakers on 7.1 system currently using Onkyo TX-RZ820 receiver, powered by Sunfire Grand Theater amp
Polk Speaker collection: SDA SRS 1.2tl x 2, SRT system, SDA SRS 2 P/B, SDA 2A, SDA 1C Studio, SDA CRS+, Monitor 7B & 4, SRS 3.1tl, RTA 15tl, LS90, LSI 9
Post edited by bluecomet on
    Toolfan66 Posts: 17,243
    edited October 2011
    First an Allan wrench will not work as they are rivited. Second what I would do is take some of the hot glue off the back side and take a pin or needle and see if you can push the pin back out..
