1.2tl Wiring Diagram Clarification
xoaphexox
Hey there,
I was looking over the 1.2tl right and left channel wiring diagrams that are uploaded to the sticky in this forum.
My question is this: are they correctly labeled? More specifically:
If standing in front of the right speaker, facing the drivers, are the white (-) wires connected to the "left" side of the 6503 drivers?
If standing in front of the left speaker, facing the drivers, these same white (-) wires connect to the "right" side of the 6503 drivers, that is - they are connected the reverse orientation of the right channel.
I took my drivers out to install new foam gaskets and now that I am looking at these wiring diagrams to put the speakers together I have myself all confused. I want to make sure I put them back together correctly.
I thought that the red dot on the rear of the driver indicated the positive terminal - but if that is the case, then the wiring diagram for the stereo drivers of the right channel is incorrect - as well as the wiring diagram for the dimensional drivers of the left channel.
Burson HA-160D > Adcom GFA-5802 > Polk SDA-SRS 1.2tl w/ Mye Sound Spikes, Mills/Sonicap XO, Larry's Rings, Dynamat Extreme, Cardas CCGR Binding Posts and Jumpers, Custom 10ga interconnect, Custom Gaskets, RDO-198
Post edited by xoaphexox on
That would make your drivers Left and Right and there is no such thing, your (-) side will be to your left facing the drivers on both speakers..Polk Audio SDA 2.3tl Fully Hot Rodded. 😎
SVS SB16 X2
Cary SLP-05/Ultimate Upgrade.
Cary SA-500.1 ES Amps
Cary DMS 800PV Network
Jolida JD9 Fully Modified
VPI MW-1 Cyclone RCM
MIT Shotgun 3 cables throughout / Except TT, and PC’s -
So the wiring diagrams are wrong, then?
Thanks for the quick reply
Burson HA-160D > Adcom GFA-5802 > Polk SDA-SRS 1.2tl w/ Mye Sound Spikes, Mills/Sonicap XO, Larry's Rings, Dynamat Extreme, Cardas CCGR Binding Posts and Jumpers, Custom 10ga interconnect, Custom Gaskets, RDO-198 -
IMO yes they are as the drivers are marked with a red dot for the (+) side and I must correct myself here as the positive will be on the right side as your looking at the back of the driver with the terminals facing the floor..Polk Audio SDA 2.3tl Fully Hot Rodded. 😎
SVS SB16 X2
When ever I work on my SDA speakers I replace things one at a time. If I am changing tweets, I take out the old tweet and immediately replace it with the new one so I don't get confused on what went where. It can be confusing with the different color wires. I hope your project turns out well.Polk HT system 1: LSIC, LSI25 mains, LSI F/X rears, Lsi F/X rear centers,
Yamaha RX-V2500 System, Carver A753 3 channel amp.
Polk HT system 2: , SRT system with f/x 1,000's rear speakers on 7.1 system currently using Onkyo TX-RZ820 receiver, powered by Sunfire Grand Theater amp
Polk Speaker collection: SDA SRS 1.2tl x 2, SRT system, SDA SRS 2 P/B, SDA 2A, SDA 1C Studio, SDA CRS+, Monitor 7B & 4, SRS 3.1tl, RTA 15tl, LS90, LSI 9 -
I have been inside my speakers so many times now I could just about do it with my eyes closed!! LOL!! it's really not that hard anymore..Polk Audio SDA 2.3tl Fully Hot Rodded. 😎
SVS SB16 X2
TOOLFORLIFEFAN wrote: »I have been inside my speakers so many times now I could just about do it with my eyes closed!! LOL!! it's really not that hard anymore..
When I modded my first vintage Polks them using the BLACK wire for a positive had my head spinning. It was like reprogramming myself lol- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
How naive of me to assume a technical diagram produced and approved by the manufacturer of the very speakers they represent would be correctly drawn and labeled!
In summation:
Green Wire -
Blue Wire +
White Wire -
Black Wire +
Red Dot on Driver +
And ignore all the arrows and "wire marker" labels on the wiring diagrams because half of them are wrong.
Thanks guys, I will get humpty dumpty back together tonight and give them a test drive.
Put the speakers together according to the summary in my last post. I don't hear anything out of the ordinary. It would be nice if Polk would confess to the wiring diagrams being incorrect just to put my mind at complete ease but in the meantime I *think* they are wired correctly.
Would I be able to tell anything by doing a 9V 'touch' test or would the SDA circuitry interfere with that sort of thing?
9-volt, or 1.5 volt? Maybe it doesn't make a difference? -
Thanks! I used a 9V and all 16 drivers pushed "out". Sounds like I'm in business. And that confirms the little arrows that indicate where the wires go in the diagram are incorrectly labeled half the time. Best to pay attention to the polarity marking and not the orientation marking.
Or, as was said, just take out one driver at a time and note its previous wiring
It's a wiring diagram only in the sense that it shows what color wire and its corresponding polarity goes to what driver, not that the green wire goes to the left terminal and the blue goes to the right. That's why Polk marked the positive terminal with a red dot to make it idiot proof. Hello!Political Correctness'.........defined
President of Club Polk -
If you had even looked at the diagrams you would see that they have arrows drawn out pointing to the incorrect terminals on half the drivers on each channel. They could have just listed the polarities and colors of each wire and been done. It's these arrows pointing to the wrong location that threw me for a loop.
Don't use a 9volt. It can hurt the drivers if kept on to long. 1.5volt battery is best.
Thanks, Joe. I did a very quick test with the 9V this morning and all drivers are operating as expected. I consider my issue satisfactorily closed, with much appreciated help from the great members of the Polk forums!
I looked. I also rely on my own common sense. Glad you finally got it figured out.Political Correctness'.........defined
