Ambiophonics anyone?
Gavin.Wright
Gavin.Wright Posts: 125
edited October 2011 in 2 Channel Audio
Hey Guys,
So I've been reading up on ambiophonics recently and took some time this weekend to setup a small system to test it out to see how it sounded. You can read up on what exactly ambiophonics is at the website http://www.ambiophonics.org/
Anyway, I downloaded the 2 channel and 4 channel (free) "transcoders" which allows you to playback 2 channel audio ambiophonically and it really makes a HUGE difference! So much so that I'm thinking about running my SDA's without the interconnect and using the software ambiophonic crosstalk cancellation as it seems to do a more accurate job. I get a much more stable center image with the ambiophonic setup and a better overall sense of the space the music was recorded in. I'd love to hear back from anyone that has more experience with this than I do and find out what you guys think of ambiophonics.
Below is a link to a pdf that goes into greater detail.
http://www.tactlab.com/Products/Ambiophonics/Ambiophonics_System.pdf
  • inspiredsports
    inspiredsports Posts: 5,502
    edited October 2011
    If it really works, it doesn't seem Polks with the IC disconnected would not be as good a choice as quality non-SDA equipped speakers.
    Conrad Johnson PV-5 w/mods
    MF x-DAC V8, HAInfo NG27
    NAD SS rigs w/mods
    GIK panels
  • Gavin.Wright
    edited October 2011
    very true - but the polks are my best directional speakers at this time. I would try it with my DQ-10's but since ambiophonics works best with a more directional speakers I would think the polks would be better...
