Looking for a TV with built-in DirecTV tuner
kevhed72
kevhed72 Posts: 5,126
edited October 2011 in Electronics
Does such a thing exist....in a mid-sized flat panel?
I need a clean install of just a flat panel TV mounted on the wall...no wires, boxes, TV stands, or any other crap.
Does such a TV exist, or any other ideas to achieve the above?
Post edited by kevhed72 on
  • mrbigbluelight
    mrbigbluelight Posts: 9,878
    edited October 2011
    Your question made me curious, so did a little googling. Didn't find a lot of results, and the results that showed up were not very encouraging.
    A Humax :eek: 20" LCD integrated off of Amazon from about 4 years ago. One negative review brought up an interesting point:
    "I purchased this unit approximately one year ago at Best Buy for $568.00. Due to an extensive remodeling project, the TV was just plugged in and the receiver does not work! Direct TV will take zero responsibility for this! Their excuse is that the TV is made by HUMAX and that the receiver isn't made by them either.
    http://www.amazon.com/Humax-20-Inch-Television-Integrated-Receiver/product-reviews/B000FTE8YK/ref=cm_cr_dp_hist_1?ie=UTF8&showViewpoints=0&filterBy=addOneStar
    Few hits on google, which would make me think that the idea was tried and not very popular/successful. That's just a guess, though.
    There was a thread on CP a little while ago about integrated TV/BluRay players. Some folks in that thread expressed an opinion that I share: start "glopping" a lot of devices into 1 unit and when one goes bad (Murphy's Law says it will), then it's a bigger pain in the rear to fix. (substitute "DirectTV" for "BluRay").
    One of our installer Polkies will certainly have more real-world, hands on experience and advice, to be sure.
    I know you're looking for a clean install, maybe a projection unit would have what your looking for ?
    Mantis will probably have some input on this.
  • jbooker82
    jbooker82 Posts: 1,627
    edited October 2011
    Dont they make a mount to tuck the direct tv box verticle behind the TV?
    AVR: Onkyo Tx-NR808
    Rear: FXI A4
    Sub: Polk DSW Pro 660wi
    TV: LG Infinia 50PX950 3D
    IC: AudioQuest Black Mamba II
  • Marty913
    Marty913 Posts: 760
    edited October 2011
    I suppose you could also investigate on of the wireless solutions available. Its gonna be a "box" nonetheless but may be smaller & lighter weight than a cable box plus do other devices. I know Vizio makes a cheap one that sells at Cosco. Gefen & Phillips have pricey versions but I'm sure there are others. What about just running the HDMI cable behind (or up in a nice conduit) the wall?
    Sony 60'' SXRD 1080p
    Amp = Carver AV-705THX 5-Channel
    Processor = NAD T747
    Panasonic BD35 Blu-Ray
    Main = SDA-1C Studio with RD0s, spikes, XO rebuild, rings, I/C upgrade
    Center=Polk CS10, Surround = Athena Dipoles, Sub= Boston 12HO
    Music/Video Streaming = Netgear NEO550
    TT = Audio Technica
