Which Sub with RTi A7 and Csi A6
Hannzz
Hannzz Posts: 34
edited November 2011 in Speakers
Hi Guys:
Could you please recommend a sub for RTi A7 (fronts) and Csi A6 (CC)? Thanks
Post edited by Hannzz on
  • jbooker82
    jbooker82 Posts: 1,627
    edited October 2011
    Best polk sub for the money. Get it now why it is on sale.
    http://www.newegg.com/Product/Product.aspx?Item=N82E16882290227&Tpk=dsw%20pro%20660wi
    It is usually on sale every other weekend usually from saturday after noon through sunday evening / early monday.
    AVR: Onkyo Tx-NR808
    Rear: FXI A4
    Sub: Polk DSW Pro 660wi
    TV: LG Infinia 50PX950 3D
    IC: AudioQuest Black Mamba II
  • nhhiep
    nhhiep Posts: 877
    edited October 2011
    or PSW505 for just 190 on newegg. best bang for the buck here
  • ken brydson
    ken brydson Posts: 8,786
    edited October 2011
    Need more than your current speakers for a recommendation. % music vs HT, room size, listening habits (wanna go BOOM or pressurize the room) and most importantly budget. I'm of the camp of getting the biggest, baddest sub you can afford. Upgadis is a cruel ****!
  • Hannzz
    Hannzz Posts: 34
    edited October 2011
    Room size is 12 x13 and mostly for movies. Budget is around 300-400. Thanks
  • Hannzz
    Hannzz Posts: 34
    edited October 2011
    People on avsforum recommended VTF-2 MK3 HSU. Is there huge difference between this and DSWPRo 660? Thanks
    F1nut Posts: 50,761
    edited October 2011
    I use the same Polk's plus FXi A6's (the rig is strictly for HT) with the DSW Pro 660wi.......love it. I've no experience with the HSU.
    tonyb Posts: 33,014
    edited October 2011
    Either one will have no problem pressurizing a room that size.
  • djperez81
    djperez81 Posts: 388
    edited October 2011
    With your setup i would go with the DSW series. I agree with Ken get the best sub you can afford because you will want to upgrade later. I think either the dsw550 or 660 should be good for you.
    Music doesn't lie. If there is something to be changed in this world, then it can only happen through music.
    -Jimi Hendrix
  • Hannzz
    Hannzz Posts: 34
    edited October 2011
    I guess I would go with 660 since it is more affordable since HSU is now 550+63 s/h. I can get 660 for $349 at newegg sales. Thanks
  • larry777
    larry777 Posts: 480
    edited October 2011
    For H/T the Hsu would be better as it punches lower overall. With the polk you will miss some of the lower tones altogether if they are present in the soundtracks.......which more movies seem to have now with the newer formats. 25 Htz range and above they would be more comparable,but then again a Sub is all about producing the lower tones overall for the best intended impact. If you can take more time, and save a little more, it may be worth it in the end to go Hsu. You can also find a lot of quality Subs on line at places like Audiogon for reduced prices. Just another option to consider.
    Home Theatre.............
    Pioneer SC-35
    Polk RTi10's Fronts
    Polk CSiA6 Center
    RTi4 Surrounds
    SVS PB-12 Sub
    2 Channel.............................
    Yaqin MC-100B
    Energy RC-70 Speakers
    Arcam CD-192 Disc Player
    Van Den Hul Interconnects
  • dpowell
    dpowell Posts: 3,068
    edited October 2011
    Also consider looking for a used SVS.
    polkaudio Fully Modded SDA SRS 1.2TLs + Dreadnaught, LSiM706c, 4 X Polk Surrounds + 4 X ATMOS, SVS PB13 Ultra X 2, Pass Labs X1, Marantz 7704, Bob Carver Crimson Beauty 350 Tube Mono Blocks, Carver Sunfire Signature Cinema Grande 400x5, ADCOM GFA 7807, Panasonic UB420, Moon 380D DAC, EPSON Pro Cinema 6050
  • danz1906
    danz1906 Posts: 5,144
    edited October 2011
    dpowell wrote: »
    Agreed!
    Linn AV5140 fronts
    Linn AV5120 Center
    Linn AV5140 Rears
    M&K MX-70 Sub for Music
    Odyssey Mono-Blocs
    SVS Ultra-13 Gloss Black:D
  • larry777
    larry777 Posts: 480
    edited October 2011
    Yes, I can also say that SVS Subs are great. I use mine for almost 100% H/T and they go real low with power.
    Pioneer SC-35
    Polk RTi10's Fronts
    Polk CSiA6 Center
    RTi4 Surrounds
    SVS PB-12 Sub
    Yaqin MC-100B
  • jbooker82
    edited October 2011
    the 660 is hard to beat for $349.
    AVR: Onkyo Tx-NR808
    Rear: FXI A4
  • reeltrouble1
    reeltrouble1 Posts: 9,312
    edited October 2011
    I would definetly get a Polk sub to play with Polk speakers for HT.
    RT1
  • Hannzz
    Hannzz Posts: 34
    edited October 2011
    jbooker82: I have noticed in your profile that you have 660, what do you think? How about lows other people are talking about. Do you miss anything by having 660 and wish for a better sub i.e., svs, hsu, epic etc...Thanks
  • jbooker82
    edited October 2011
    There is always the drive to get bigger and better. It just depends on what your budget is. I would love to have a SVS PB13 Ultra, or a JL Gotham. You get a really good sub for your money when you buy a DSW Pro 660WI for $349. Now if your looking to buy it at the $600 retail price then you really should look around. How much of a difference there is you really dont know until you have tried both of them in your normal listening environment.
    I originaly started out with a DSW Pro 550WI. I had it for 8 months and upgraded to a 660, and was happy I did. It plays a little lower and has more of an impact feel.
    Set your budget and find the best sub that is within it.
    AVR: Onkyo Tx-NR808
    Rear: FXI A4
  • Hannzz
    Hannzz Posts: 34
    edited October 2011
    I think you are right, there is no end in terms of how much you want to spend on these things speakers, amp, receivers but I have to see my budget as well. At newegg it is 349 and no shipping. while for these other companies you have to pay 60 to 70 in shipping another cost. currently, I am using energy take classic 5.1. I am hoping polk 660 sub would be better than energy sub came with energy take classic 5.1, and I like it.
  • jbooker82
    edited October 2011
    Well it looks like your current sub has a -3db point of 33 hz so the 660WI will play lower. Stepping up from a Home Theater in a Box setup you will notice a very significant improvement.
    Your current sub is a 200 watt 8" driver, it should be a night and day difference.
    AVR: Onkyo Tx-NR808
    Rear: FXI A4
  • larry777
    larry777 Posts: 480
    edited October 2011
    Hannzz wrote: »
    jbooker82: How about lows other people are talking about. Do you miss anything by having 660 and wish for a better sub i.e., svs, hsu, epic etc...Thanks
    The point is...... you won't know you missed anything if a particular Sub dosn't go low enough to produce the intended signal. It may be in the soundtrack to add that extra impact,but if the Sub dosn't go low enough it won't play it. That can be a good thing also, as you won't know you are missing anything.
    Pioneer SC-35
    Polk RTi10's Fronts
    Polk CSiA6 Center
    RTi4 Surrounds
    SVS PB-12 Sub
    Yaqin MC-100B
  • Hannzz
    Hannzz Posts: 34
    edited October 2011
    Thanks guys for all of your help. I am going with Polk 660. One other reason is that I am from Canada/Vancouver and from warranty point of view I can send to a local Polk repair shop, while for other brands I have to ship US and gonna cost me around $160...
  • larry777
    larry777 Posts: 480
    Good Choice. But thought I would let you know that SVS Subs can be purchased in Canada from Sonic Boom Audio. They are in Ontario and shipping is fast ( Thats where I had mine shipped from to Nova Scotia ). They also have the full warranty with these subs. A heads up in case you didn't realize SVS can be purchased in Canada......thats all. HSU has to ship from the USA though.
    Pioneer SC-35
    Polk RTi10's Fronts
    Polk CSiA6 Center
    RTi4 Surrounds
    SVS PB-12 Sub
    Yaqin MC-100B
