Speaker wire connections?
Dabutcher
Dabutcher Posts: 2,624
First of all I would like to thank everyone who contributes to this blog. You all have helped me a lot. Remember back in the day when ol school speaker wire had one side copper and other side silver colored wire? What was that other wire made from and if I picked up some twelve or ten gauge speaker wire with one side copper and other side silver colored wire. Is it ok to use or should I run? Also if copper sides showing some green does that affect performance? As always thanks,Darryl
Post edited by Dabutcher on
    txcoastal1 Posts: 13,519
    edited October 2011
    Go solid copper----the silver is a copper nickel alloy would not recommend
  • rebuy
    rebuy Posts: 694
    edited October 2011
    Green is Not good. I bought some wire and it has green too, ICK! :evil:
    I changed it out ASAP. That is corrosion and that makes for a bad connection.
    Get some good quality wire that doesn't have corrosion and is a decent gauge and you should be fine.
    The lower the gauge, the better.
    Now get out the wallet cause you are about to get advice on how to spend your money on speaker wire.:cheesygrin:
  • fbm211
    fbm211 Posts: 1,488
    edited October 2011
    Canare 4S11 is a great starter cable and the best bang for the buck speaker cable. IMO
    SDA-2BTL with custom IC
    Harman Kardon T-55c TT
    DH LABS REVELATIONS ICs-amps
    Revelation Audio Labs Paradise cryo-silver ICs-Source to pre
  • thetawave2
    thetawave2 Posts: 268
    edited October 2011
    Agreed. I prettied up some Canare 4S11 with techflex and cable pants and terminated it with banana plugs. Made for a pretty awesome set of wires! I would definitely recommend this cable, finished or unfinished. The individual strands of copper are very sturdy.
    My Stereo: Tannoy D100s, Yaqin MC-100B, VPI Traveler, Dynavector 10x5 MC Phono Cartridge, heavily modified Yaqin MS-22B phono preamp, TEAC EQA-20 equalizer, Belkin PureAV PF30 Power Conditioner, Canare 4s11 speaker cables, Custom dust cover from DigitalDeckCovers
  • Mr. Sharpe
    Mr. Sharpe Posts: 1,359
    edited October 2011
    txcoastal1 wrote: »
    Agree, the copper nickel is used in cheap wire.
    Home theater:
    43” Westinghouse Displayer
    Marantz UD-7007 Player
    Emotiva MC-700 Processor
    Adcom GFA-5006 Amplifier
    Parasound Zamp Amplifier
    Ethereal ESO-1 Power Conditioner
    Klipsch RC-10 Center
    Klipsch R34c Fronts
    Klipsch RB-41 Surrounds
    Polk audio PSW-505
    Stereo:
    Polk audio RTA-12c’s fully upgraded crossovers
    DIY 12tc braided speaker cables
    Denon DVD-5910ci Spinner
    Parasound P6 Preamplifer
    Parasound HCA -1500a Amplifier
  • codyc1ark
    codyc1ark Posts: 2,539
    edited October 2011
    Another vote for the Canare, I swapped it out over some older monster cable, made an improvement to my ears. FWIW. - bluejeanscable.com
