CSI A4 vs A6
Drenis
Drenis Posts: 2,871
edited October 2011 in Speakers
So I did a quick search and nothing came up when I typed the title in, however I have a question that might be up for debate from some of you.
The RTI A9's use 5 1/4" drivers in a sealed area along with the tweeter. Some users have said the best center to timbre match is the A6 which has dual 6 1/2 drivers (used in the A7 tower) with tweeter.
Has anyone used the A4 instead? The A4 uses the same drivers and tweeter and to me, would match MORE than the A6. I can see the A6 taking away from the A9 drivers.
Discuss?
EDIT: Also, take into consideration that these would receive mods to the crossovers.
Post edited by Drenis on
  • nhhiep
    nhhiep Posts: 877
    edited October 2011
    if price is your concern. check out Csi5. same as A6 as far as sound and a lot cheaper.I am using it with my Rti12 set (same as A9s)
  • Drenis
    Drenis Posts: 2,871
    edited October 2011
    Price has nothing to do with it.
  • nhhiep
    nhhiep Posts: 877
    edited October 2011
    then I am not sure why are you still thinking about it? Even Polk suggests A6. remember that for center, bigger is always better, more than 50% of what you hear come from the center.
  • Upstatemax
    Upstatemax Posts: 2,801
    edited October 2011
    I don't agree with bigger is always better at all...
    I sent my A6 back for an A4. The A6 sounded bloated and artificial to me. Male vocals were boomy and I felt like they did not mesh with my A7's at all.
    Swapping to the A4 solved all of the issues and you'll have to pry it from my cold dead hands.
    I know many people will not agree with me, but I just don't see why there is such a love affair with the A6.
  • SRTer
    SRTer Posts: 372
    edited October 2011
    Upstatemax wrote: »
    I have both the CSi A6 and A4 in my home. I find the total opposite. The A6 sound fuller than the A4.
    Could some of your difference be in the automatic calibration that your AVR uses? They often adjust a EQ to change the sound to what the reciever measures to be better.
    Either are fine, but I believe that the CSi A6 is the center that brings the goods home. Especially at reference level Blu-ray play back.
    Fronts: Polk RTi A9
    Center: Polk CSI A6
    Rears: Polk RTi A7
    Receiver: Pioneer Elite SC-35 (140 watts x 7)
    Amplifier: Adcom GFA-555 Mk.II (200 watt @ 8 ohms)
    Sub: Polk DSW PRO 500 (10 inch, 200 Watt)
    TV: Samsung 59 inch 3D Plasma 600 Hz PN59D7000
    Sources: Samsung BD-D6700 3D Blu-ray Player, DirecTV, PS3, iPhone 4 and IPod Classic with Apple Lossless Tracks
  • Drenis
    Drenis Posts: 2,871
    edited October 2011
    Thanks for the opinions fellas. Still waiting to read more about this.
  • mole'
    mole' Posts: 3,160
    edited October 2011
    never heard the CSia4 tho
    i have the CSi3 ,CSi5 and the CSia6
    to me the CSia6 just sounded better.......
    ran them with my RTi10s
    SRTer wrote: »
    i agree
    mole'
  • B Run
    B Run Posts: 1,888
    edited October 2011
    Different line but when I compared the CS1 with the CS2, the bigger drivers sounded much better. I had the same thought process and wanted it to match the 5 1/4 drivers in my old Monitor 60's, but it sounded much better with the CS2 and it blended just fine.
  • mufsoman
    mufsoman Posts: 636
    edited October 2011
    My Csi A6 sounds great with the Rti 12's. I've never heard an A4 in comparison, but have no need to, sound is awesome. If you want big sound to match the towers, I would go for the big daddy - A6 !!!!
    Sony 83A80L TV and Roku Ultra
    Denon 3800
    Parasound HCA-2205A
    SVS Prime towers, center channel and bookshelfs (side surrounds)
    Atmos: Mirage Nanosats x 4
    Turbo MFW-15 x 2
    Panasonic DP-UB820
    APC H15
    Morrow MA4 & AQ Cobra IC's, AQ Midnight speaker cables
  • BtrSound
    BtrSound Posts: 123
    edited October 2011
    I listened to both side by side to evaluate which one to buy. They both sound really good. The sound stage for the RTIA6 was much better, but it is HUGE. I would say, if size is not a concern, go with the A6, but if it is a concern at all go with the A4. The size difference between the two is significant.
  • SRTer
    SRTer Posts: 372
    edited October 2011
    BtrSound wrote: »
    This is very true. Many people didn't give much thought to where or how they are going to fit the center channel in the room. The CSi A6 is a beast in size and must have a proper room for it.
    Therefore, for your viewing pleasure.
    I have taken pictures of both my CSi A6 and A4 together.
    Fronts: Polk RTi A9
    Center: Polk CSI A6
    Rears: Polk RTi A7
  • jbooker82
    jbooker82 Posts: 1,627
    edited October 2011
    SRTer wrote: »
    What is the exact hight and width of that CSI A6?
    AVR: Onkyo Tx-NR808
    Rear: FXI A4
    Sub: Polk DSW Pro 660wi
    TV: LG Infinia 50PX950 3D
    IC: AudioQuest Black Mamba II
  • SRTer
    SRTer Posts: 372
    edited October 2011
    jbooker82 wrote: »
    These are the measurements of the CSi A6
    7 3/4" H x 24" W x 14" D
    These are the measurements of the CSi A4
    6 7/8" H x 20" W x 8 3/4" D
    Pulled from the Polk Audio site.
    http://www.polkaudio.com/homeaudio/rtia/specs.php#center
    Fronts: Polk RTi A9
    Center: Polk CSI A6
    Rears: Polk RTi A7
  • kevhed72
    kevhed72 Posts: 5,163
    edited October 2011
    If size is not an issue, go for the largest center possible.
  • gp4jesus
    gp4jesus Posts: 2,019
    edited October 2011
    Upstatemax wrote: »
    ...they did not mesh with my A7's at all.
    Placement of center in cabinet or LR in room could be factors. While a more remote posibility, unusual interaction w/AVR
    either way, my sig says it all!
    cheers tony
    *all connected w/Premiere ICs
