Need advice for the rear speakers
Ne007
Ne007 Posts: 1
edited October 2011 in Speakers
Hi,
I am currently building my HT and I need some advice. I have read a lot of reviews/comments on forums but now I am stuck on one last part of the build, the rear speakers.
First of all, here's what I got or plan to purchase:
Front : Monitor 70
Central : CS-20
Sub : Polk PSW-110
Receiver : Denon AVR-1912
Now, I need to choose the rear speakers... the thing is that I'm in Canada. I was going to buy the Monitor 30 but It doesn't seems to be available anymore in Canada. Neither is the monitor 40. So Now I'm looking at 3 models that fit my budget : TS100, M10 or R150. I have read that you better try to fit the speakers series but it seems impossible to do, except if I'm willing to pay ridiculous brokerage fees.
Which bookshelfs speakers would you recommand considering the rest of the build ? I rather have a better sound in Music listening (5.1 blu-ray show) than in Movies.
One last question I would have his, would it make a really big difference to get the TS200 instead of TS100 ? Considering right now that there's almost $100 difference between the 2 in Canada.
Thanks a lot for your help/advice! I really appreciate if some of you would share their experience/wisdom! :)
Post edited by Ne007 on
  • rebuy
    rebuy Posts: 695
    edited October 2011
    From what your options are I would go with TSI 100. They should be fine for surround.
  • tommyt21
    tommyt21 Posts: 685
    edited October 2011
    I had the r150's and they sucked. Using M40's and their awsome
    Living Room
    Fronts: RTi A7's
    Center: Csi A6 VR3 "Fortress Plus"
    Front Heights: Rti A1
    Surrounds: Rti A3
    Sub: HSU VTF-2 MK4 Damn this is a good SUB
    Pioneer Pioneer Elite: SC-35-> Emotiva XPA-3
    TV: Lg LW6500 55" Passive 3D
    Blu-Ray Panasonic BD 210
    XboX 360 Slim/Kinect
    Acoustimac red suede panels
